On 05/08/2017 02:59 PM, Kasemir, Kay wrote:
>> On 05/08/2017 02:22 PM, [email protected] wrote:
>>> Actually empty name check is already done in CAJ (see CAJContext.java,
>>> createChannel method):
> Matej is correct.
> While the JCAChannel would allow a zero length PV name, the CAJContext
> wouldn't actually hand you such a channel.
> I see now that even if CS-Studio code tries to get a zero length PV from
> the CAJ lib, it will instead see
> java.lang.IllegalArgumentException: null or empty channel name
> at com.cosylab.epics.caj.CAJContext.createChannel(CAJContext.java:942)
> Based on the tech-talk message
> http://www.aps.anl.gov/epics/tech-talk/2017/msg00714.php and our own CA
> gateway log showing the same "zero length PV name in UDP search request?"
> error, originating from a CS-Studio client, I erroneously assumed we'd
> create such empty PV names on purpose.
>>> If it wasn't added recently, how was it
>>> possible for CS-Studio to be sending out requests for zero-length names
>>> over the network?
>> Bug in constructing search request messages?
>>> Does Java's String class permit '\0' characters to be
>>> included in the string perhaps?
>> Yes, it does.
> Would it make sense to add code to the CAJ client code that constructs
> search messages to guard against empty or "\000" PV names?
> That way we'd get a stack trace the next time the CAJ client tries to send
> such malformed search requests.
CAJ should reject any PV name that starts with a \0 character. Both the
RSRV and PCAS servers will reject names with a leading \0, and will
truncate a name at the first \0 they see after the first character, but
from CAS code comments it looks like it isn't illegal for non-zero
characters to follow a terminating \0 since older client versions might
not zero-fill their payload buffer.
> Finally, it's also possible that the PCAS server lib has a bug, i.e. the
> search requests aren't really for empty PV names.
There must be a bug somewhere since the gateway shouldn't be looping
when it sees a bad name request like was originally reported. The CAS
code looks right but whether the problem is in the CAS or the Gateway I
don't know. I did file a bug report against the Gateway since the CAS
code looks right at that point.
I believe Michael has some Python code for testing the CA protocol; this
would probably be a good test to add to that.
- Andrew
Re: windows build/test failures Andrew Johnson
Build failed in Jenkins: epics-base-3.16-mac-test #97 APS Jenkins
<2017>
Jenkins build is back to normal : epics-base-3.16-win64s #107 APS Jenkins
<2017>
