Hi Michael,
Please look at db_access.patch, and let me know what you think.
LAST_TYPE should be DBF_NO_ACCESS instead of DBF_DOUBLE, is it right?
The present definition looks correct to me. It did confuse me for a
moment until I noticed the '<='
#define VALID_DB_FIELD(x) ((x >= 0) && (x <= LAST_TYPE))
I don't follow your explanation. The present definition is following :
#define DBF_STRING 0
#define DBF_INT 1
#define DBF_SHORT 1
#define DBF_FLOAT 2
#define DBF_ENUM 3
#define DBF_CHAR 4
#define DBF_LONG 5
#define DBF_DOUBLE 6
#define DBF_NO_ACCESS 7
#define LAST_TYPE DBF_DOUBLE
#define INVALID_DB_FIELD(x) ((x < 0) || (x > LAST_TYPE))
If this is correct, what is DBF_NO_ACCESS within that definition? Is
it in INVALID_DB_FIELD?
And similarly in dbf_type_is_valid().
Yes, I saw the similarity in dbf_type_is_valid(). In addition,
However it is inconsistent if we compare DBR_* with DBF_*. That is the
first very naive thought I had to create a patch. Then I think, it is
more than what I think as usual.
I found the interesting discussion in tech-talk.
http://www.aps.anl.gov/epics/tech-talk/2002/msg00137.php
It's actually not apparent to me that 'DBF_NO_ACCESS' can have any valid
use. Other than appearing in dbf_text[] it doesn't seem to do anything.
And hey, what do you know. RSRV isn't bounds checking the requested DBR
type code in event_add_action(), read_notify_action(), or read_action().
It uses the dbr_size_n() macro which doesn't bounds check it's first
argument, or look for overflow.
I didn't commit my change anywhere, so I just generated the
db_access.patch via
I just execute the following command (got from Michael)
$ git format-patch -k -1
I should have mentioned that this command is only useful after you commit.
I though so, but I prefer not to commit anything to anywhere. :) Once
I understand the epics base better than, I will use this command to
create a patch for the community. Thank you again.
Han
P.S. Is this right place to discuss this subject? Or do anyone want me
to move this subject to the normal tech-talk? It is the sort of
question, which I have now, while I am studying more EPICS itself.
- Re: Database Field type in db_access.h Michael Davidsaver
- Database Field type in db_access.h Jeong Han Lee
Jenkins build is back to normal : epics-base-3.16-mac #101 APS Jenkins
<2017>
<2017>
