See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/96/display/redirect?page=changes>
Changes:
[Michael Davidsaver] rsrv: ignore echo and unexpected UDP
[Michael Davidsaver] rsrv: UDP search ignore DOREPLY
[Michael Davidsaver] rsrv: send channel create failure
[Michael Davidsaver] cas: ignore echo and unexpected UDP
[Michael Davidsaver] cas: honor DOREPLY for TCP searches
[Michael Davidsaver] rsrv: ignore CA client version older than v4.4
[Michael Davidsaver] rsrv: no ca exception response to UDP
[Michael Davidsaver] rsrv: remove !CA_V44() code
[Michael Davidsaver] cas: ignore CA client version older than v4.4
[Andrew Johnson] Check for empty PV names in Perl catools
[Michael Davidsaver] libCom: STATIC_ASSERT use c++11 static_assert when possible
[Michael Davidsaver] libCom/test: errlog test more verbose
[Andrew Johnson] Fix indentation warning from GCC
[Michael Davidsaver] ioc/dbStatic: whitespace
[Michael Davidsaver] ioc/dbStatic: plug leak in dbFreeBase()
[Michael Davidsaver] ioc/dbStatic: dbFreeBase() don't double free alias'd records
[Michael Davidsaver] missing include
[Michael Davidsaver] Added functions to allow access to what functions and variables the ioc
[Michael Davidsaver] whitespace
[Michael Davidsaver] more whitespace
[Michael Davidsaver] Changed function outputs to remove pointer to next function.
[Michael Davidsaver] Added patch
[Michael Davidsaver] rename iocshFind -> iocshFindCommand
[Michael Davidsaver] update RELEASE_NOTES
[...truncated 688.51 KB...]
db_test.c
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ioc/O.win32-x86'>
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ioc/O.win32-x86'>
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/recGbl.c
recGbl.c
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/build/O.win32-x86'>
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release -version:3.16 -out:cas.dll -implib:cas.lib caServer.obj caServerI.obj casCoreClient.obj casDGClient.obj casStrmClient.obj casPV.obj casPVI.obj casChannel.obj casChannelI.obj casAsyncIOI.obj casAsyncReadIO.obj casAsyncReadIOI.obj casAsyncWriteIO.obj casAsyncWriteIOI.obj casAsyncPVExistIO.obj casAsyncPVExistIOI.obj casAsyncPVAttachIO.obj casAsyncPVAttachIOI.obj casEventSys.obj casMonitor.obj casMonEvent.obj inBuf.obj outBuf.obj casCtx.obj casEventMask.obj ioBlocked.obj casBufferFactory.obj pvExistReturn.obj pvAttachReturn.obj caNetAddr.obj beaconTimer.obj beaconAnomalyGovernor.obj clientBufMemoryManager.obj chanIntfForPV.obj channelDestroyEvent.obj casIntfOS.obj casDGIntfOS.obj casStreamOS.obj caServerIO.obj casIntfIO.obj casDGIntfIO.obj casStreamIO.obj ipIgnoreEntry.obj cas.res ../../../../../../lib/win32-x86/ca.lib ../../../../../../lib/win32-x86/gdd.lib ../../../../../../lib/win32-x86/Com.lib ws2_32.lib
Creating library cas.lib and object cas.exp
Generating code
Finished generating code
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/build/O.win32-x86'>
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/callback.c
callback.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/initHooks.c
initHooks.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbCa.c
dbCa.c
../../../src/ioc/db/dbCa.c(494) : warning C4018: '>' : signed/unsigned mismatch
../../../src/ioc/db/dbCa.c(841) : warning C4018: '<=' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbCaTest.c
dbCaTest.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/cvtBpt.c
cvtBpt.c
make -C ./example install.win32-x86
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbContext.cpp
dbContext.cpp
c:\jenkins\win32-1\workspace\epics-base-3.16-win32\src\ioc\db\dbChannelNOOP.h(83) : warning C4138: '*/' found outside of comment
../../../src/ioc/db/dbContext.cpp(75) : warning C4800: 'int' : forcing value to bool 'true' or 'false' (performance warning)
make -C ./directoryService install.win32-x86
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbSubscriptionIO.cpp
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/example/directoryService'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/bin/win32-x86/makeMakefile.pl> O.win32-x86 ../../../../../../..
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/example/directoryService'>
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../../../../../../.. \
T_A=win32-x86 install
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbPutNotifyBlocker.cpp
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbChannelIO.cpp
dbChannelIO.cpp
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbIocRegister.c
dbIocRegister.c
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbContextReadNotifyCache.cpp
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/chfPlugin.c
chfPlugin.c
../../../src/ioc/db/chfPlugin.c(371) : warning C4018: '<' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbState.c
dbState.c
make[5]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/example/directoryService/O.win32-x86'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/bin/win32-x86/mkmf.pl> -m directoryServer.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../../include/compiler/msvc -I../../../../../../../include/os/WIN32 -I../../../../../../../include directoryServer.obj ../directoryServer.cc
make[5]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/src/ca/legacy/pcas/example/directoryService/O.win32-x86'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32/ws/bin/win32-x86/mkmf.pl> -m main.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../../include/compiler/msvc -I../../../../../../../include/os/WIN32 -I../../../../../../../include main.obj ../main.cc
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbServer.c
dbServer.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/db/dbUnitTest.c
dbUnitTest.c
../../../src/ioc/db/dbUnitTest.c(133) : warning C4244: '=' : conversion from 'double' to 'epicsFloat32', possible loss of data
../../../src/ioc/db/dbUnitTest.c(254) : warning C4018: '<' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c dbYacc.c
dbYacc.c
../../../src/ioc/dbStatic\dbLexRoutines.c(376) : warning C4018: '<=' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/dbStatic/dbStaticLib.c
dbStaticLib.c
../../../src/ioc/dbStatic/dbStaticLib.c(320) : warning C4018: '<' : signed/unsigned mismatch
../../../src/ioc/dbStatic/dbStaticLib.c(2555) : warning C4018: '>=' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/dbStatic/dbStaticRun.c
dbStaticRun.c
../../../src/ioc/dbStatic/dbStaticRun.c(108) : warning C4018: '>=' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/dbStatic/dbPvdLib.c
dbPvdLib.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/dbStatic/dbStaticIocRegister.c
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../../../../../include/compiler/msvc -I../../../../../../../include/os/WIN32 -I../../../../../../../include -c ../directoryServer.cc
directoryServer.cc
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/dbtemplate/dbtoolsIocRegister.c
cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I.. -I../../../../../../../include/compiler/msvc -I../../../../../../../include/os/WIN32 -I../../../../../../../include -c ../main.cc
main.cc
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c dbLoadTemplate.c
dbLoadTemplate.c
../../../src/ioc/dbtemplate/dbLoadTemplate_lex.l(224) : warning C4013: 'read' undefined; assuming extern returning int
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/misc/epicsRelease.c
epicsRelease.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/misc/dlload.c
dlload.c
link -nologo -LTCG -incremental:no -opt:ref -release -version:3.16 -out:caDirServ.exe main.obj directoryServer.obj ../../../../../../../lib/win32-x86/cas.lib ../../../../../../../lib/win32-x86/ca.lib ../../../../../../../lib/win32-x86/gdd.lib ../../../../../../../lib/win32-x86/Com.lib ws2_32.lib advapi32.lib user32.lib
Generating code
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/misc/iocshRegisterCommon.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/misc/iocInit.c
iocInit.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/misc/miscIocRegister.c
miscIocRegister.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryDeviceSupport.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryRecordType.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryDriverSupport.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryFunction.c
registryFunction.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryCommon.c
registryCommon.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/registry/registryIocRegister.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I../../../src/ca/client -c ../../../src/ioc/rsrv/caserverio.c
caserverio.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/rsrv/caservertask.c
caservertask.c
../../../src/ioc/rsrv/caservertask.c(164) : warning C4018: '<' : signed/unsigned mismatch
../../../src/ioc/rsrv/caservertask.c(176) : warning C4018: '<' : signed/unsigned mismatch
../../../src/ioc/rsrv/caservertask.c(225) : warning C4018: '<=' : signed/unsigned mismatch
../../../src/ioc/rsrv/caservertask.c(260) : warning C4018: '<' : signed/unsigned mismatch
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/rsrv/camsgtask.c
camsgtask.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -I../../../src/ca/client -c ../../../src/ioc/rsrv/camessage.c
camessage.c
../../../src/ioc/rsrv/camessage.c(1213) : error C2143: syntax error : missing ';' before 'type'
../../../src/ioc/rsrv/camessage.c(1214) : error C2143: syntax error : missing ';' before 'type'
../../../src/ioc/rsrv/camessage.c(1224) : error C2065: 'pName' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1224) : error C2109: subscript requires array or pointer type
../../../src/ioc/rsrv/camessage.c(1226) : error C2065: 'dbch' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1226) : error C2065: 'pName' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1226) : warning C4047: 'function' : 'const char *' differs in levels of indirection from 'int'
../../../src/ioc/rsrv/camessage.c(1226) : warning C4024: 'dbChannel_create' : different types for formal and actual parameter 1
../../../src/ioc/rsrv/camessage.c(1226) : warning C4047: '=' : 'int' differs in levels of indirection from 'dbChannel *'
../../../src/ioc/rsrv/camessage.c(1227) : error C2065: 'dbch' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1242) : error C2065: 'dbch' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1242) : warning C4047: 'function' : 'dbChannel *' differs in levels of indirection from 'int'
../../../src/ioc/rsrv/camessage.c(1242) : warning C4024: 'casCreateChannel' : different types for formal and actual parameter 2
../../../src/ioc/rsrv/camessage.c(1251) : error C2065: 'dbch' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1251) : error C2223: left of '->addr' must point to struct/union
../../../src/ioc/rsrv/camessage.c(1251) : error C2198: 'send_err' : too few arguments for call
../../../src/ioc/rsrv/camessage.c(1253) : error C2065: 'dbch' : undeclared identifier
../../../src/ioc/rsrv/camessage.c(1253) : warning C4047: 'function' : 'dbChannel *' differs in levels of indirection from 'int'
../../../src/ioc/rsrv/camessage.c(1253) : warning C4024: 'dbChannelDelete' : different types for formal and actual parameter 1
../../../configure/RULES_BUILD:229: recipe for target 'camessage.obj' failed
make[3]: *** [camessage.obj] Error 2
make[3]: *** Waiting for unfinished jobs....
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/rsrv/rsrvIocRegister.c
rsrvIocRegister.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/rsrv/cast_server.c
cast_server.c
cl -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/ioc/as -I../../../src/ioc/bpt -I../../../src/ioc/db -I../../../src/ioc/dbStatic -I../../../src/ioc/dbtemplate -I../../../src/ioc/misc -I../../../src/ioc/registry -I../../../src/ioc/rsrv -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/ioc/rsrv/online_notify.c
online_notify.c
../../configure/RULES_ARCHS:58: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'ioc.install.win32-x86' failed
make[1]: *** [ioc.install.win32-x86] Error 2
configure/RULES_DIRS:84: recipe for target 'src.install.win32-x86' failed
make: *** [src.install.win32-x86] Error 2
C:\jenkins\win32-1\workspace\epics-base-3.16-win32>exit 2
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.16-win32 #97 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win64 #92 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32s #96 APS Jenkins
<2017>
Jenkins build is back to normal : epics-base-3.16-win64 #95 APS Jenkins
<2017>
