Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Build failed in Jenkins: epics-base-3.15-win32s-test #108
To: core-talk@aps.anl.gov
Date: Thu, 27 Apr 2017 13:10:42 -0400
On 04/24/2017 12:34 PM, APS Jenkins wrote:
> src/std/filters/test/O.win32-x86-static/arrTest.tap ............. ok
> src/std/filters/test/O.win32-x86-static/dbndTest.tap ............
> Failed 43/59 subtests
> src/std/filters/test/O.win32-x86-static/syncTest.tap ............ ok
> src/std/filters/test/O.win32-x86-static/tsTest.tap .............. ok
> src/std/rec/test/O.win32-x86-static/analogMonitorTest.tap ....... ok
> src/std/rec/test/O.win32-x86-static/arrayOpTest.tap ............. ok
> src/std/rec/test/O.win32-x86-static/regressTest.tap ............. ok
> Test Summary Report
> src/std/filters/test/O.win32-x86-static/dbndTest.tap          (Wstat: 0 Tests: 16 Failed: 0)
>   Parse errors: Bad plan.  You planned 59 tests but ran 16.
> Files=72, Tests=8578,  6 wallclock secs ( 0.97 usr  0.48 sys +  0.35 cusr  3.57 csys =  5.37 CPU)
> Result: FAIL
> Build step 'Execute shell' marked build as failure
Running dbndTest through valgrind throws up a lot of invalid read
errors.  These are presumably causing crashes in some cases.  Seems to
be related to record field access.
Build failed in Jenkins: epics-base-3.15-win32s-test #107 APS Jenkins
Build failed in Jenkins: epics-base-3.15-win32s-test #108 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.14 #247 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win32s-test #111 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Build failed in Jenkins: epics-base-3.15-win32s-test #108 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win64s-test #96 APS Jenkins
ANJ, 27 Apr 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
