Subject: |
changes to libCom/osi/os/osdThread.c to be used for RTEMS 4.12 |
Heinz Junkes <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 26 Apr 2017 11:52:44 +0200 |
Dear Andrew, dear Michael,
I know you both are very busy. I hope you will find some time to review my changes at Labor-Day (1th of Mai except in US ;-) ).
Heinz
rtems@epics:~/EPICS/add-rtems-4.12-api$ bzr diff src/libCom/osi/os/posix/osdThread.c
=== modified file 'src/libCom/osi/os/posix/osdThread.c'
--- src/libCom/osi/os/posix/osdThread.c 2016-02-23 21:43:26 +0000
+++ src/libCom/osi/os/posix/osdThread.c 2017-04-21 14:53:21 +0000
@@ -4,11 +4,19 @@
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
* Copyright (c) 2013 ITER Organization.
+* Copyright (c) 2017 Fritz-Haber-Institut der Max-Planck-Gesellschaft
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
-/* Author: Marty Kraimer Date: 18JAN2000 */
+/* Author: Marty Kraimer Date: 18JAN2000
+ Heinz Junkes Date: 06APR2017
+ once() and all called functions by once must use
+ checkStatusOnce and checkStatusQuitOnce only
+ including epicsEventCreate called by create_threadInfo
+ add epicsEventCreateOnce which can be called here
/* This is a posix implementation of epicsThread */
#include <stddef.h>
@@ -38,6 +46,16 @@
#include "errlog.h"
#include "epicsAssert.h"
#include "epicsExit.h"
+#if defined(__rtems__)
+#include <rtems/bspIo.h>
+#include <rtems.h>
+#endif
+struct epicsEventOSD {
+ pthread_mutex_t mutex;
+ pthread_cond_t cond;
+ int isFull;
epicsShareFunc void epicsThreadShowInfo(epicsThreadOSD *pthreadInfo, unsigned int level);
epicsShareFunc void osdThreadHooksRun(epicsThreadId id);
@@ -75,14 +93,15 @@
} priAvailable;
#endif
-static pthread_key_t getpthreadInfo;
+__thread epicsThreadOSD *tls_pthreadInfo;
static pthread_mutex_t onceLock;
static pthread_mutex_t listLock;
static ELLLIST pthreadList = ELLLIST_INIT;
static commonAttr *pcommonAttr = 0;
-static int epicsThreadOnceCalled = 0;
+static int epicsThreadInitOnceCalled = 0;
-static epicsThreadOSD *createImplicit(void);
+static void createImplicit(void);
#define checkStatus(status,message) \
if((status)) {\
@@ -90,7 +109,7 @@
#define checkStatusQuit(status,message,method) \
-if(status) { \
+if((status)) { \
errlogPrintf("%s error %s\n",(message),strerror((status))); \
cantProceed((method)); \
@@ -99,17 +118,33 @@
/* Until epicsThreadInit completes errlogInit will not work */
/* It must also be used by init_threadInfo otherwise errlogInit could get */
/* called recursively */
+#if defined (__rtems__)
+#define checkStatusOnce(status,message) \
+if((status)) {\
+ printk("%s error %s\n",(message),strerror((status))); }
+#else
if((status)) {\
fprintf(stderr,"%s error %s\n",(message),strerror((status))); }
+#endif
-#define checkStatusOnceQuit(status,message,method) \
-if(status) { \
+#define checkStatusOnceQuit(status,message,method) \
+if((status)) { \
+ printk("%s error %s",(message),strerror((status))); \
+ printk(" %s\n",method); \
+ printk("epicsThreadInit cant proceed. Program exiting\n"); \
+ exit(-1);\
+#else
+if((status)) { \
fprintf(stderr,"%s error %s",(message),strerror((status))); \
fprintf(stderr," %s\n",method); \
fprintf(stderr,"epicsThreadInit cant proceed. Program exiting\n"); \
exit(-1);\
+#endif
epicsShareFunc int epicsThreadGetPosixPriority(epicsThreadId pthreadInfo)
@@ -153,6 +188,29 @@
#endif /* _POSIX_THREAD_PRIORITY_SCHEDULING */
+epicsShareFunc epicsEventId epicsEventCreateOnce(epicsEventInitialState init)
+ epicsEventId pevent = malloc(sizeof(*pevent));
+ if (pevent) {
+ int status = pthread_mutex_init(&pevent->mutex, 0);
+ pevent->isFull = (init == epicsEventFull);
+ if (status) {
+ checkStatus(status, "pthread_mutex_init");
+ } else {
+ status = pthread_cond_init(&pevent->cond, 0);
+ if (!status)
+ return pevent;
+ checkStatus(status, "pthread_cond_init");
+ status = pthread_mutex_destroy(&pevent->mutex);
+ checkStatus(status, "pthread_mutex_destroy");
+ free(pevent);
+ return NULL;
static epicsThreadOSD * create_threadInfo(const char *name)
epicsThreadOSD *pthreadInfo;
@@ -161,7 +219,7 @@
pthreadInfo = calloc(1,sizeof(*pthreadInfo) + strlen(name));
if(!pthreadInfo)
return NULL;
- pthreadInfo->suspendEvent = epicsEventCreate(epicsEventEmpty);
+ pthreadInfo->suspendEvent = epicsEventCreateOnce(epicsEventEmpty);
if(!pthreadInfo->suspendEvent){
free(pthreadInfo);
return NULL;
@@ -204,11 +262,13 @@
int status;
- status = mutexLock(&listLock);
- checkStatusQuit(status,"pthread_mutex_lock","free_threadInfo");
- if(pthreadInfo->isOnThreadList) ellDelete(&pthreadList,&pthreadInfo->node);
- status = pthread_mutex_unlock(&listLock);
- checkStatusQuit(status,"pthread_mutex_unlock","free_threadInfo");
+ if(pthreadInfo->isOnThreadList) {
+ status = mutexLock(&listLock);
+ checkStatusQuit(status,"pthread_mutex_lock","free_threadInfo");
+ ellDelete(&pthreadList,&pthreadInfo->node);
+ status = pthread_mutex_unlock(&listLock);
+ checkStatusQuit(status,"pthread_mutex_unlock","free_threadInfo");
epicsEventDestroy(pthreadInfo->suspendEvent);
status = pthread_attr_destroy(&pthreadInfo->attr);
checkStatusQuit(status,"pthread_attr_destroy","free_threadInfo");
@@ -301,13 +361,19 @@
arg.ok = 0;
status = pthread_create(&id, 0, find_pri_range, &arg);
- checkStatusQuit(status, "pthread_create","epicsThreadInit");
+ checkStatusOnceQuit(status, "pthread_create","findPriorityRange");
status = pthread_join(id, &dummy);
- checkStatusQuit(status, "pthread_join","epicsThreadInit");
+ checkStatusOnceQuit(status, "pthread_join","findPriorityRange");
+// We are using posix map osi 0-100 to posix 100-200
+// see epicsThreadGetOsiPriorityValue(int ossPriority)
+ a_p->minPriority = 100;
+ a_p->maxPriority = 200;
+#else
a_p->minPriority = arg.min_pri;
a_p->maxPriority = arg.max_pri;
+#endif
a_p->usePolicy = arg.ok;
#endif
@@ -315,18 +381,15 @@
static void once(void)
- epicsThreadOSD *pthreadInfo;
int status;
- pthread_key_create(&getpthreadInfo,0);
status = pthread_mutex_init(&onceLock,0);
- checkStatusQuit(status,"pthread_mutex_init","epicsThreadInit");
+ checkStatusOnceQuit(status,"pthread_mutex_init","once");
status = pthread_mutex_init(&listLock,0);
pcommonAttr = calloc(1,sizeof(commonAttr));
- if(!pcommonAttr) checkStatusOnceQuit(errno,"calloc","epicsThreadInit");
+ if(!pcommonAttr) checkStatusOnceQuit(errno,"calloc","once");
status = pthread_attr_init(&pcommonAttr->attr);
- checkStatusOnceQuit(status,"pthread_attr_init","epicsThreadInit");
+ checkStatusOnceQuit(status,"pthread_attr_init","once");
status = pthread_attr_setdetachstate(
&pcommonAttr->attr, PTHREAD_CREATE_DETACHED);
checkStatusOnce(status,"pthread_attr_setdetachstate");
@@ -358,52 +421,77 @@
if (errVerbose) {
+ printk("LRT: min priority: %d max priority %d\n",
+ pcommonAttr->minPriority, pcommonAttr->maxPriority);
+#else
fprintf(stderr, "LRT: min priority: %d max priority %d\n",
+#endif
#else
- if(errVerbose) fprintf(stderr,"task priorities are not implemented\n");
+ if(errVerbose) {
+ printk("task priorities are not implemented\n");
+#else
+ fprintf(stderr,"task priorities are not implemented\n");
+#endif
+ int policy;
+ struct sched_param param;
+ status = pthread_getschedparam(pthread_self(), &policy, ¶m);
+ checkStatusOnce(status, "pthread_getschedparam failed");
+// param.sched_priority is still 2 bug or feature?
+ param.sched_priority = 191; // iocsh prio
+#endif
+ status = pthread_setschedparam(pthread_self(), policy, ¶m);
+ checkStatusOnce(status, "pthread_setschedparam failed");
- pthreadInfo = init_threadInfo("_main_",0,epicsThreadGetStackSize(epicsThreadStackSmall),0,0);
- assert(pthreadInfo!=NULL);
- status = pthread_setspecific(getpthreadInfo,(void *)pthreadInfo);
- checkStatusOnceQuit(status,"pthread_setspecific","epicsThreadInit");
+ tls_pthreadInfo = init_threadInfo("_main_",param.sched_priority-100,epicsThreadGetStackSize(epicsThreadStackSmall),0,0);
+#else
+ tls_pthreadInfo = init_threadInfo("_main_",0,epicsThreadGetStackSize(epicsThreadStackSmall),0,0);
+#endif
+ assert(tls_pthreadInfo!=NULL);
+ tls_pthreadInfo->tid = pthread_self();
- checkStatusQuit(status,"pthread_mutex_lock","epicsThreadInit");
- ellAdd(&pthreadList,&pthreadInfo->node);
- pthreadInfo->isOnThreadList = 1;
+ checkStatusOnceQuit(status,"pthread_mutex_lock","once");
+ ellAdd(&pthreadList,&tls_pthreadInfo->node);
+ tls_pthreadInfo->isOnThreadList = 1;
- checkStatusQuit(status,"pthread_mutex_unlock","epicsThreadInit");
+ checkStatusOnceQuit(status,"pthread_mutex_unlock","once");
status = atexit(epicsExitCallAtExits);
checkStatusOnce(status,"atexit");
- osdThreadHooksRunMain(pthreadInfo);
- epicsThreadOnceCalled = 1;
+ osdThreadHooksRunMain(tls_pthreadInfo);
+ epicsThreadInitOnceCalled = 1;
static void * start_routine(void *arg)
- epicsThreadOSD *pthreadInfo = (epicsThreadOSD *)arg;
int status;
sigset_t blockAllSig;
+ tls_pthreadInfo = (epicsThreadOSD *)arg;
sigfillset(&blockAllSig);
pthread_sigmask(SIG_SETMASK,&blockAllSig,NULL);
- status = pthread_setspecific(getpthreadInfo,arg);
- checkStatusQuit(status,"pthread_setspecific","start_routine");
checkStatusQuit(status,"pthread_mutex_lock","start_routine");
checkStatusQuit(status,"pthread_mutex_unlock","start_routine");
- osdThreadHooksRun(pthreadInfo);
+ osdThreadHooksRun(tls_pthreadInfo);
- (*pthreadInfo->createFunc)(pthreadInfo->createArg);
+ (*tls_pthreadInfo->createFunc)(tls_pthreadInfo->createArg);
epicsExitCallAtThreadExits ();
- free_threadInfo(pthreadInfo);
+ free_threadInfo(tls_pthreadInfo);
return(0);
@@ -417,6 +505,9 @@
epicsShareFunc
void epicsThreadRealtimeLock(void)
+#if !defined(__rtems__)
+/* RTEMS defines _POSIX_MEMLOCK to 1 in features.h even if it is a non swaping OS and
+ mlockall senseless*/
#if defined(_POSIX_MEMLOCK) && _POSIX_MEMLOCK > 0
if (pcommonAttr->maxPriority > pcommonAttr->minPriority) {
int status = mlockall(MCL_CURRENT | MCL_FUTURE);
@@ -424,10 +515,11 @@
if (status) {
fprintf(stderr, "epicsThreadRealtimeLock "
"Warning: Unable to lock the virtual address space.\n"
- "VM page faults may harm real-time performance.\n");
+ "VM page fautls may harm real-time performance.\n");
#endif
+#endif /* not defined __rtems__ */
epicsShareFunc unsigned int epicsShareAPI epicsThreadGetStackSize (epicsThreadStackSizeClass stackSizeClass)
@@ -463,37 +555,33 @@
epicsThreadInit();
status = mutexLock(&onceLock);
- if(status) {
- fprintf(stderr,"epicsThreadOnce: pthread_mutex_lock returned %s.\n",
- strerror(status));
- exit(-1);
+ checkStatusOnceQuit(status,"pthread_mutex_lock", "epicsThreadOnce");
if (*id != EPICS_THREAD_ONCE_DONE) {
if (*id == EPICS_THREAD_ONCE_INIT) { /* first call */
*id = epicsThreadGetIdSelf(); /* mark active */
status = pthread_mutex_unlock(&onceLock);
- checkStatusQuit(status,"pthread_mutex_unlock", "epicsThreadOnce");
+ checkStatusOnceQuit(status,"pthread_mutex_unlock", "epicsThreadOnce");
func(arg);
- checkStatusQuit(status,"pthread_mutex_lock", "epicsThreadOnce");
*id = EPICS_THREAD_ONCE_DONE; /* mark done */
} else if (*id == epicsThreadGetIdSelf()) {
cantProceed("Recursive epicsThreadOnce() initialization\n");
} else
while (*id != EPICS_THREAD_ONCE_DONE) {
/* Another thread is in the above func(arg) call. */
epicsThreadSleep(epicsThreadSleepQuantum());
- checkStatusQuit(status,"pthread_mutex_unlock","epicsThreadOnce");
+ checkStatusOnceQuit(status,"pthread_mutex_unlock","epicsThreadOnce");
epicsShareFunc epicsThreadId epicsShareAPI epicsThreadCreate(const char *name,
@@ -530,6 +618,7 @@
return 0;
status = pthread_sigmask(SIG_SETMASK,&oldSig,NULL);
+//? StatusOnce? because of errlog daemon ???
checkStatusOnce(status,"pthread_sigmask");
return(pthreadInfo);
@@ -537,80 +626,64 @@
* Create dummy context for threads not created by epicsThreadCreate().
char name[64];
pthread_t tid;
- int status;
sprintf(name, "non-EPICS_%ld", (long)tid);
- pthreadInfo = create_threadInfo(name);
- assert(pthreadInfo);
- pthreadInfo->tid = tid;
- pthreadInfo->osiPriority = 0;
+ tls_pthreadInfo = create_threadInfo(name);
+ assert(tls_pthreadInfo);
+ tls_pthreadInfo->tid = tid;
+ tls_pthreadInfo->osiPriority = 0;
#if defined(_POSIX_THREAD_PRIORITY_SCHEDULING) && _POSIX_THREAD_PRIORITY_SCHEDULING > 0
int policy;
if(pthread_getschedparam(tid,&policy,¶m) == 0)
(param.sched_priority - pcommonAttr->minPriority) * 100.0 /
- (pcommonAttr->maxPriority - pcommonAttr->minPriority + 1);
+ (pcommonAttr->maxPriority - pcommonAttr->minPriority);
- checkStatus(status,"pthread_setspecific createImplicit");
- if(status){
- return NULL;
- return pthreadInfo;
epicsShareFunc void epicsShareAPI epicsThreadSuspendSelf(void)
epicsThreadInit();
- pthreadInfo = (epicsThreadOSD *)pthread_getspecific(getpthreadInfo);
- if(pthreadInfo==NULL)
- pthreadInfo = createImplicit();
- pthreadInfo->isSuspended = 1;
- epicsEventWait(pthreadInfo->suspendEvent);
+ tls_pthreadInfo->isSuspended = 1;
+ epicsEventWait(tls_pthreadInfo->suspendEvent);
epicsShareFunc void epicsShareAPI epicsThreadResume(epicsThreadOSD *pthreadInfo)
- assert(epicsThreadOnceCalled);
+ assert(epicsThreadInitOnceCalled);
pthreadInfo->isSuspended = 0;
epicsEventSignal(pthreadInfo->suspendEvent);
epicsShareFunc void epicsShareAPI epicsThreadExitMain(void)
epicsThreadInit();
- if(pthreadInfo->createFunc) {
+ if(tls_pthreadInfo==NULL)
+ createImplicit();
+ if(tls_pthreadInfo->createFunc) {
errlogPrintf("called from non-main thread\n");
cantProceed("epicsThreadExitMain");
else {
pthread_exit(0);
epicsShareFunc unsigned int epicsShareAPI epicsThreadGetPriority(epicsThreadId pthreadInfo)
return(pthreadInfo->osiPriority);
@@ -626,7 +699,7 @@
int status;
if(!pthreadInfo->isEpicsThread) {
fprintf(stderr,"epicsThreadSetPriority called by non epics thread\n");
@@ -637,7 +710,7 @@
#if defined (_POSIX_THREAD_PRIORITY_SCHEDULING) && _POSIX_THREAD_PRIORITY_SCHEDULING > 0
if(!pcommonAttr->usePolicy) return;
- pthreadInfo->schedParam.sched_priority = epicsThreadGetPosixPriority(pthreadInfo);
+ tls_pthreadInfo->schedParam.sched_priority = epicsThreadGetPosixPriority(pthreadInfo);
status = pthread_attr_setschedparam(
&pthreadInfo->attr,&pthreadInfo->schedParam);
if(errVerbose) checkStatus(status,"pthread_attr_setschedparam");
@@ -685,14 +758,14 @@
epicsShareFunc int epicsShareAPI epicsThreadIsEqual(epicsThreadId p1, epicsThreadId p2)
assert(p1);
assert(p2);
return(pthread_equal(p1->tid,p2->tid));
epicsShareFunc int epicsShareAPI epicsThreadIsSuspended(epicsThreadId pthreadInfo) {
return(pthreadInfo->isSuspended ? 1 : 0);
@@ -718,14 +791,11 @@
epicsShareFunc epicsThreadId epicsShareAPI epicsThreadGetIdSelf(void) {
epicsThreadInit();
- assert ( pthreadInfo );
- return(pthreadInfo);
+ createImplicit();
+ return(tls_pthreadInfo);
epicsShareFunc pthread_t epicsThreadGetPosixThreadId ( epicsThreadId threadId )
@@ -737,7 +807,7 @@
int status;
checkStatus(status,"pthread_mutex_lock epicsThreadGetId");
if(status)
@@ -755,18 +825,16 @@
epicsShareFunc const char epicsShareAPI *epicsThreadGetNameSelf()
epicsThreadInit();
- return(pthreadInfo->name);
+ createImplicit();
+ return(tls_pthreadInfo->name);
epicsShareFunc void epicsShareAPI epicsThreadGetName(epicsThreadId pthreadInfo, char *name, size_t size)
strncpy(name, pthreadInfo->name, size-1);
name[size-1] = '\0';
@@ -822,7 +890,7 @@
return;
- checkStatus(status,"pthread_mutex_lock epicsThreadShowAll");
+ checkStatus(status,"pthread_mutex_lock epicsThreadShow");
if(status)
return;
pthreadInfo=(epicsThreadOSD *)ellFirst(&pthreadList);
@@ -835,7 +903,7 @@
pthreadInfo=(epicsThreadOSD *)ellNext(&pthreadInfo->node);
- checkStatus(status,"pthread_mutex_unlock epicsThreadShowAll");
+ checkStatus(status,"pthread_mutex_unlock epicsThreadShow");
if(status) return;
if (!found)
printf("Thread %#lx (%lu) not found.\n", (unsigned long)showThread, (unsigned long)showThread);
@@ -851,7 +919,8 @@
if(!key)
return NULL;
status = pthread_key_create(key,0);
- checkStatus(status,"pthread_key_create epicsThreadPrivateCreate");
+//used from errlogInit
+ checkStatusOnce(status,"pthread_key_create epicsThreadPrivateCreate");
if(status)
return NULL;
return((epicsThreadPrivateId)key);
@@ -862,7 +931,7 @@
pthread_key_t *key = (pthread_key_t *)id;
int status;
status = pthread_key_delete(*key);
checkStatusQuit(status,"pthread_key_delete","epicsThreadPrivateDelete");
free((void *)key);
@@ -873,7 +942,7 @@
int status;
if(errVerbose && !value)
errlogPrintf("epicsThreadPrivateSet: setting value of 0\n");
status = pthread_setspecific(*key,value);
@@ -884,7 +953,7 @@
return pthread_getspecific(*key);
smime.p7s
Description: S/MIME cryptographic signature
- Re: changes to libCom/osi/os/osdThread.c to be used for RTEMS 4.12 Michael Davidsaver
Build failed in Jenkins: epics-base-3.14 #246 APS Jenkins
Jenkins build is back to normal : epics-base-3.15-win64 #293 APS Jenkins
<2017>
<2017>
