2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.15-win32 #277
To: [email protected]
Date: Fri, 21 Apr 2017 17:55:52 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32/277/display/redirect>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32/ws/>
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files (x86)/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files (x86)/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse "origin/3.15^{commit}" # timeout=10
Checking out Revision 22b10adf29bcf43964d1fea0b1fb06bd05679696 (origin/3.15)
 > C:/Program Files (x86)/Git/bin/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe checkout -f 22b10adf29bcf43964d1fea0b1fb06bd05679696
 > C:/Program Files (x86)/Git/bin/git.exe rev-list 22b10adf29bcf43964d1fea0b1fb06bd05679696 # timeout=10
Cleaning workspace
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files (x86)/Git/bin/git.exe reset --hard # timeout=10
 > C:/Program Files (x86)/Git/bin/git.exe clean -fdx # timeout=10
FATAL: Command "C:/Program Files (x86)/Git/bin/git.exe clean -fdx" returned status code 1:
stdout: Removing bin/
Removing configure/O.Common/
Removing configure/O.win32-x86-static/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing src/ca/client/O.Common/
Removing src/ca/client/O.win32-x86-static/
Removing src/ca/client/perl/O.Common/
Removing src/ca/client/perl/O.win32-x86-static/
Removing src/ca/client/tools/O.Common/
Removing src/ca/client/tools/O.win32-x86-static/
Removing src/ca/legacy/gdd/O.Common/
Removing src/ca/legacy/gdd/O.win32-x86-static/
Removing src/ca/legacy/pcas/build/O.Common/
Removing src/ca/legacy/pcas/build/O.win32-x86-static/
Removing src/ca/legacy/pcas/ex/O.Common/
Removing src/ca/legacy/pcas/ex/O.win32-x86-static/
Removing src/ca/legacy/pcas/example/directoryService/O.Common/
Removing src/ca/legacy/pcas/example/directoryService/O.win32-x86-static/
Removing src/ioc/O.Common/
Removing src/ioc/O.win32-x86-static/
Removing src/ioc/db/test/O.Common/
Removing src/ioc/db/test/O.win32-x86-static/
Removing src/ioc/dbtemplate/test/O.Common/
Removing src/ioc/dbtemplate/test/O.win32-x86-static/
Removing src/libCom/O.Common/
Removing src/libCom/O.win32-x86-static/
Removing src/libCom/RTEMS/O.Common/
Removing src/libCom/RTEMS/O.win32-x86-static/
Removing src/libCom/test/O.Common/
Removing src/libCom/test/O.win32-x86-static/
Removing src/std/O.Common/
Removing src/std/O.win32-x86-static/
Removing src/std/filters/test/O.Common/
Removing src/std/filters/test/O.win32-x86-static/arrRecord.d
Removing src/std/filters/test/O.win32-x86-static/arrRecord.obj
Removing src/std/filters/test/O.win32-x86-static/arrTest.d
Removing src/std/filters/test/O.win32-x86-static/arrTest.dbd.d
Removing src/std/filters/test/O.win32-x86-static/arrTest.exe
Removing src/std/filters/test/O.win32-x86-static/arrTest.obj
Removing src/std/filters/test/O.win32-x86-static/arrTest.t
Removing src/std/filters/test/O.win32-x86-static/arrTest.tap
Removing src/std/filters/test/O.win32-x86-static/arrTest_registerRecordDeviceDriver.cpp
Removing src/std/filters/test/O.win32-x86-static/arrTest_registerRecordDeviceDriver.d
Removing src/std/filters/test/O.win32-x86-static/arrTest_registerRecordDeviceDriver.obj
Removing src/std/filters/test/O.win32-x86-static/dbndTest.d
Removing src/std/filters/test/O.win32-x86-static/dbndTest.dbd.d
Removing src/std/filters/test/O.win32-x86-static/dbndTest.exe
Removing src/std/filters/test/O.win32-x86-static/dbndTest.obj
Removing src/std/filters/test/O.win32-x86-static/dbndTest.t
Removing src/std/filters/test/O.win32-x86-static/dbndTest.tap
Removing src/std/filters/test/O.win32-x86-static/dbndTest_registerRecordDeviceDriver.cpp
Removing src/std/filters/test/O.win32-x86-static/dbndTest_registerRecordDeviceDriver.d
Removing src/std/filters/test/O.win32-x86-static/dbndTest_registerRecordDeviceDriver.obj
Removing src/std/filters/test/O.win32-x86-static/Recs.lib
Removing src/std/filters/test/O.win32-x86-static/syncTest.d
Removing src/std/filters/test/O.win32-x86-static/syncTest.dbd.d
Removing src/std/filters/test/O.win32-x86-static/syncTest.exe
Removing src/std/filters/test/O.win32-x86-static/syncTest.obj
Removing src/std/filters/test/O.win32-x86-static/syncTest.t
Removing src/std/filters/test/O.win32-x86-static/syncTest.tap
Removing src/std/filters/test/O.win32-x86-static/syncTest_registerRecordDeviceDriver.cpp
Removing src/std/filters/test/O.win32-x86-static/syncTest_registerRecordDeviceDriver.d
Removing src/std/filters/test/O.win32-x86-static/syncTest_registerRecordDeviceDriver.obj
Removing src/std/filters/test/O.win32-x86-static/testspec
Removing src/std/filters/test/O.win32-x86-static/tsTest.d
Removing src/std/filters/test/O.win32-x86-static/tsTest.dbd.d
Removing src/std/filters/test/O.win32-x86-static/tsTest.exe
Removing src/std/filters/test/O.win32-x86-static/tsTest.obj
Removing src/std/filters/test/O.win32-x86-static/tsTest.t
Removing src/std/filters/test/O.win32-x86-static/tsTest.tap
Removing src/std/filters/test/O.win32-x86-static/tsTest_registerRecordDeviceDriver.cpp
Removing src/std/filters/test/O.win32-x86-static/tsTest_registerRecordDeviceDriver.d
Removing src/std/filters/test/O.win32-x86-static/tsTest_registerRecordDeviceDriver.obj
Removing src/std/filters/test/O.win32-x86-static/xRecord.d
Removing src/std/filters/test/O.win32-x86-static/xRecord.obj
Removing src/std/rec/test/O.Common/
Removing src/std/rec/test/O.win32-x86-static/
Removing src/template/base/O.Common/
Removing src/template/base/O.win32-x86-static/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.win32-x86-static/
Removing src/tools/O.Common/
Removing src/tools/O.win32-x86-static/
Removing src/tools/test/O.Common/
Removing src/tools/test/O.win32-x86-static/
Removing templates/
stderr: warning: failed to remove src/std/filters/test/O.win32-x86-static/
hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/bin/git.exe clean -fdx" returned status code 1:
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing templates/
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1799)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1772)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1768)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1415)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1427)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:679)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:894)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:869)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:828)
	at hudson.remoting.UserRequest.perform(UserRequest.java:153)
	at hudson.remoting.UserRequest.perform(UserRequest.java:50)
	at hudson.remoting.Request$2.run(Request.java:336)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	at ......remote call to win32-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1545)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
	at hudson.remoting.Channel.call(Channel.java:830)
	at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:257)
	at com.sun.proxy.$Proxy83.clean(Unknown Source)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl.clean(RemoteGitImpl.java:450)
	at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:28)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1170)
	at hudson.scm.SCM.checkout(SCM.java:496)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1278)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
	at hudson.model.Run.execute(Run.java:1728)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:405)
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.15-win32 #278 APS Jenkins
Build failed in Jenkins: epics-base-3.15-win32 #276 APS Jenkins
Prev: Jenkins build is back to stable : epics-base-3.14-mac #158 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win32s-test #106 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Build failed in Jenkins: epics-base-3.15-win32 #276 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-win32 #278 APS Jenkins
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
