Subject: |
RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c |
Heinz Junkes <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 20 Apr 2017 13:27:29 +0200 |
With RTEMS (4.11.99, aka 4.12) setting the IP_MULTICAST_LOOP for the loopback gives
Had to use sizeof char as argument for the IP_MULTICAST_LOOP setsockopt call.
Changed it to
int intTrue = 1;
if (setsockopt (beaconSocket, SOL_SOCKET, SO_BROADCAST,
(char *)&intTrue, sizeof(intTrue))<0) {
cantProceed("CAS: online socket set up error\n");
#ifdef IP_ADD_MEMBERSHIP
#if defined(__rtems__)
char flag = 1;
#else
int flag = 1;
#endif
if (setsockopt(beaconSocket, IPPROTO_IP, IP_MULTICAST_LOOP,
(char *)&flag, sizeof(flag))<0) {
char sockErrBuf[64];
epicsSocketConvertErrnoToString (
sockErrBuf, sizeof ( sockErrBuf ) );
errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
#endif
/* populate the interface address list (default is empty) */
rtems@epics:~/EPICS/add-rtems-4.12-api$ diff -Naur src/ioc/rsrv/caservertask.c /tmp/caservertask.c
--- src/ioc/rsrv/caservertask.c 2017-04-20 13:21:40.613544330 +0200
+++ /tmp/caservertask.c 2017-04-20 13:23:06.537549469 +0200
@@ -307,17 +307,13 @@
-#if defined(__rtems__)
- char flag = 1;
-#else
int flag = 1;
-#endif
- errlogPrintf("rsrv: failed to set mcast loopback (%d:%s)\n", errno, sockErrBuf);
+ errlogPrintf("rsrv: failed to set mcast loopback\n");
#endif
smime.p7s
Description: S/MIME cryptographic signature
- Re: RTEMS: rsrv: failed to set mcast loopback in src/ioc/rsrv/caservertask.c Heinz Junkes
Build failed in Jenkins: epics-base-3.15-win32s-test #103 APS Jenkins
<2017>
Jenkins build is back to normal : epics-base-3.15-win64 #289 APS Jenkins
<2017>
