2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.14-win32 #221
To: [email protected]
Date: Tue, 11 Apr 2017 12:20:48 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32/221/display/redirect>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32/ws/>
 > "C:/Program Files (x86)/Git/bin/git.exe" rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > "C:/Program Files (x86)/Git/bin/git.exe" config remote.origin.url https://git.launchpad.net/~epics-core/epics-base/+git/epics-base # timeout=10
Cleaning workspace
 > "C:/Program Files (x86)/Git/bin/git.exe" rev-parse --verify HEAD # timeout=10
No valid HEAD. Skipping the resetting
 > "C:/Program Files (x86)/Git/bin/git.exe" clean -fdx # timeout=10
Fetching upstream changes from https://git.launchpad.net/~epics-core/epics-base/+git/epics-base
 > "C:/Program Files (x86)/Git/bin/git.exe" --version # timeout=10
Setting http proxy: 146.137.70.70:9091
 > "C:/Program Files (x86)/Git/bin/git.exe" fetch --tags --progress https://git.launchpad.net/~epics-core/epics-base/+git/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/~epics-core/epics-base/+git/epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:806)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1070)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1101)
	at hudson.scm.SCM.checkout(SCM.java:495)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1278)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
	at hudson.model.Run.execute(Run.java:1728)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:404)
Caused by: hudson.plugins.git.GitException: Command ""C:/Program Files (x86)/Git/bin/git.exe" fetch --tags --progress https://git.launchpad.net/~epics-core/epics-base/+git/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: unable to access 'https://git.launchpad.net/~epics-core/epics-base/+git/epics-base/': couldn't connect to proxy at 146.137.70.70:9091
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1799)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1525)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:65)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:316)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
	at hudson.remoting.UserRequest.perform(UserRequest.java:153)
	at hudson.remoting.UserRequest.perform(UserRequest.java:50)
	at hudson.remoting.Request$2.run(Request.java:336)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	at ......remote call to win32-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1537)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
	at hudson.remoting.Channel.call(Channel.java:822)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
	at sun.reflect.GeneratedMethodAccessor205.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
	at com.sun.proxy.$Proxy82.execute(Unknown Source)
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:804)
	... 11 more
ERROR: null
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-win32 #222 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win32 #220 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win32 #220 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win32 #222 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
