See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32/199/display/redirect>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win32/ws/>
> C:/Program Files (x86)/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files (x86)/Git/cmd/git.exe config remote.origin.url git+ssh://[email protected]/~epics-core/epics-base/+git/epics-base # timeout=10
Cleaning workspace
> C:/Program Files (x86)/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
No valid HEAD. Skipping the resetting
> C:/Program Files (x86)/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from git+ssh://[email protected]/~epics-core/epics-base/+git/epics-base
> C:/Program Files (x86)/Git/cmd/git.exe --version # timeout=10
using GIT_SSH to set credentials Jenkins account SSH key
> C:/Program Files (x86)/Git/cmd/git.exe fetch --tags --progress git+ssh://[email protected]/~epics-core/epics-base/+git/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from git+ssh://[email protected]/~epics-core/epics-base/+git/epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:806)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1070)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1101)
at hudson.scm.SCM.checkout(SCM.java:495)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1278)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
at hudson.model.Run.execute(Run.java:1728)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:98)
at hudson.model.Executor.run(Executor.java:404)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/cmd/git.exe fetch --tags --progress git+ssh://[email protected]/~epics-core/epics-base/+git/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: error: cannot spawn C:\Users\jenkins\ssh8806944752871544114.bat: No such file or directory
fatal: unable to fork
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1799)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1525)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:65)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:316)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:153)
at hudson.remoting.UserRequest.perform(UserRequest.java:50)
at hudson.remoting.Request$2.run(Request.java:336)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at ......remote call to win32-1(Native Method)
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1537)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:253)
at hudson.remoting.Channel.call(Channel.java:822)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor822.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy92.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:804)
... 11 more
ERROR: null
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.14-win32 #200 APS Jenkins
- Build failed in Jenkins: epics-base-3.14-win32 #198 APS Jenkins
<2017>
<2017>
