On 03/08/2017 06:50 PM, Michael Davidsaver wrote:
> Sort of... maybe. Perhaps you could give it a spin in an actual device
> support? How would you use this to replicate my aSub which returns the
> first non-INVALID input? I'm interested how/if you can avoid copying in
> the input values twice (minor for scalars, not so far arrays).
See attached.
There is still the limitation that the aSub process() routine gets all
of the INPx links before it calls the user's routine, and I'm not
checking that the A-… fields are configured as strings (causing the INPx
CA subscriptions to be strings), but this should do what you want (again
this is not tested, and in this case I haven't even tried to compile it).
- Andrew
static long try_input(struct link *plink, void *priv)
epicsEnum16 sevr, stat;
long opts = 0, nReq = 1;
if (dbGetAlarm(plink, &sevr, &stat))
return -1;
if (sevr != NO_ALARM)
return -1;
return dbGetLink(plink, DBR_STRING, priv, opts, nReq);
static
long select_string(aSubRecord *prec)
unsigned i;
DBLINK *L = &prec->inpa;
char *out = prec->vala;
/* find the first input w/o an active alarm */
for (i = 0; i < NINPUTS; i++) {
if (!dbLinkDoLocked(&L[i], try_input, out))
return 0;
out[0] = '\0';
(void)recGblSetSevr(prec, READ_ALARM, INVALID_ALARM);
return 0;
- Concerns about link-support-2 branch Andrew Johnson
- Re: Concerns about link-support-2 branch Michael Davidsaver
- Re: Concerns about link-support-2 branch Johnson, Andrew N.
- Re: Concerns about link-support-2 branch Andrew Johnson
epicsExport.h on Windows Ralph Lange
<2017>
dllPath.bat problem Mark Rivers
<2017>
