Hello Ben,
I won't comment on the wider topic of your proposed changes, but
with regard to the motor record specifically, I agree with the
changes I see in your motor module fork; https://github.com/bfrk/motor.
I suggest that these changes be added to motorRecord.cc
537c537
< static long init_record(dbCommon* arg, int pass)
> static long init_record(motorRecord *pmr, int pass)
539d538
< motorRecord *pmr = (motorRecord *) arg;
1188c1187
< static long process(dbCommon *arg)
> static long process(motorRecord *pmr)
1190d1188
since this workaround is no longer needed, and without the above
changes, init_record() and process() become unresolved external
references.
I have successfully built your motor module fork against your EPICSbase
3.16 branch (after making the above changes to
motorRecord.cc). I plan on running an IOC and actually driving a
motor. I'll let you know my results when available.
The most controversial issue is that the use of the conditional
compilation macro EPICS_VERSION_INT will make this version of the
motor record incompatible with EPICSbase versions < 3.15. It
should not be too difficult to change conditional compilation macro
usage so that EPICSbase 3.14, 3.15 and 3.16 are supported.
Ron
Jenkins build is still unstable: epics-base-3.14-win32s #181 APS Jenkins
Re: Concerns about link-support-2 branch Michael Davidsaver
<2017>
Re: const-constraints on struct rset method arguments Benjamin Franksen
Jenkins build became unstable: epics-base-3.14-win32s #180 APS Jenkins
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
