Hi Freddie,
On 01/24/2017 11:02 AM, [email protected] wrote:
> set "PATH=A & B;C"
> PATH C;%PATH%
> Prints
> 'B' is not recognized as an internal or external command,
> operable program or batch file.
> and PATH is left containing just C;A
> The solution is to quote the entire expression using the syntax
> SET "PATH=epicsdir1;epicsdir2;%PATH%"
> in dllPath.bat
Presumably
PATH "epicsdir1;epicsdir2;%PATH%"
will also work (seems to be OK for me), i.e. I just need to add quotes
around the whole generated argument.
I prefer using the slightly shorter PATH command, which also makes it
easier for a human to see at first glance that it's adjusting the PATH
instead of setting some other variable whose name just begins with PATH.
Done — thanks,
- Andrew
- RE: dllPath.bat problem freddie.akeroyd
- dllPath.bat problem Mark Rivers
- Re: dllPath.bat problem Andrew Johnson
- RE: dllPath.bat problem Mark Rivers
<2017>
<2017>
