Hi Mark,
OK, I just merged my fix from 3.14 up to the Base-3.15 branch. A few
other white-space changes (removal of trailing spaces) were also added
by the Atom editor that I'm currently trying out.
- Andrew
On 01/16/2017 03:58 PM, Mark Rivers wrote:
> Hi Andrew,
>> I will commit this change to Base (3.14 version)
> Thanks, I saw your commit on the 3.14 branch.
> I am actually running 3.15.5 now, so I needed a fix for 3.15. This is what I did locally on my system:
> corvette:base-3.15.5/src/tools>
> diff -U3 convertRelease.pl.orig convertRelease.pl
> --- convertRelease.pl.orig 2017-01-16 13:58:35.650816372 -0600
> +++ convertRelease.pl 2017-01-16 14:01:21.853482937 -0600
> @@ -119,15 +119,15 @@
> unlink $outfile;
> open(OUT, ">$outfile") or die "$! creating $outfile";
> print OUT "\@ECHO OFF\n";
> - print OUT "PATH \%PATH\%;", join(';', binDirs()), "\n";
> + print OUT "PATH ", join(';', binDirs()), ";\%PATH\%\n";
> close OUT;
> sub relPaths {
> unlink $outfile;
> - print OUT "export PATH=\$PATH:",
> - join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()), "\n";
> + print OUT "export PATH=",
> + join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs()), ":\$PATH\n";
> close OUT;
> It seems to work for dllPath.bat. I have not tested relPaths.sh.
> Mark
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: Monday, January 16, 2017 10:35 AM
> To: [email protected]
> Subject: Re: dllPath.bat problem
> Hi Mark,
> On 01/14/2017 05:14 PM, Mark Rivers wrote:
>> The EPICS build system can construct a dllPath.bat file in an ioc boot
>> directory. This is very convenient when running IOCs built dynamically
>> for Windows. An example of such a file is the one built in
>> asyn/iocBoot/iocTest.
>> corvette:asyn/iocBoot/ioctest>more dllPath.bat
>> @ECHO OFF
>> PATH
>> %PATH%;/home/epics/support/asyn-4-31/bin/linux-x86_64;/corvette/home/epics/support/seq-2-2-4/bin/linux-x86_64;/corvette/usr/local/epics/base-3.15.5/bin/linux-x86_64
>> However, I think there is an issue with these files. Note that it puts
>> the current PATH at the beginning of the new path, rather than at the
>> end. This means that if the current path contains a DLL with the same
>> name as a DLL created by EPICS, it will use the one in the current path,
>> not the one that EPICS created. It seems to me that this is the wrong
>> thing to do, for several reasons:
>> - What if the current path happens to contain, for example, a
>> DLL called "com.dll" or "ca.dll" which is completely unrelated to
>> EPICS. It will use the wrong DLL.
>> - What if the current path contains an older version of one of
>> the DLLs that EPICS built. This is what just happened to me. I have
>> the Anaconda Python bin/ directory in my path, and it contains
>> hdf5.dll. It is an older version of the HDF5 library. EPICS
>> areaDetector builds hdf5.dll using the latest code, actually patched
>> beyond anything the HDF5 group had yet released. My IOC won't run,
>> because the old DLL does not contain the symbols added recently.
>> Are there any circumstances under which the current behavior would be
>> desired?
> Good point, I agree that for the reasons you describe the current output
> is wrong.
> An equivalent fix is also required for the relPaths.sh script, which is
> the Cygwin equivalent of the dllPath.bat file for those running IOCs
> under Cygwin and bash.
> I will commit this change to Base (3.14 version):
>> === modified file 'src/tools/convertRelease.pl'
>> --- src/tools/convertRelease.pl 2016-07-07 21:43:29 +0000
>> +++ src/tools/convertRelease.pl 2017-01-16 16:22:42 +0000
>> unlink $outfile;
>> + print OUT "PATH ", join(';', binDirs(), '%PATH%'), "\n";
>> close OUT;
>> sub relPaths {
>> unlink $outfile;
>> + join(':', map {m/\s/ ? "\"$_\"" : $_ } binDirs(), '$PATH'), "\n";
>> close OUT;
> - Andrew
- RE: dllPath.bat problem freddie.akeroyd
- dllPath.bat problem Mark Rivers
- Re: dllPath.bat problem Andrew Johnson
- RE: dllPath.bat problem Mark Rivers
Build failed in Jenkins: epics-base-3.15-mac-test #107 APS Jenkins
<2017>
<2017>
