I just downloaded base-3.14.12.6 and I see that epicsExceptionTest is no
longer present.
It builds just fine on fedora 25.
Marty
On 01/12/2017 06:22 AM, Marty Kraimer wrote:
I upgraded from fedora 23 to fedora25.
epics base builds except for src/libCom/test/epicsExceptionTest.cpp
It causes the following compiler error:
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_
-DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I.
-I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc
-I../../../../include/os/Linux -I../../../../include -c
../epicsExceptionTest.cpp
../epicsExceptionTest.cpp: In function ‘void
epicsExceptionTestPrivate()’:
../epicsExceptionTest.cpp:61:49: error: size of array is too large
char * p = new char [unsuccessfulNewSize];
../epicsExceptionTest.cpp:74:38: error: size of array is too large
../../../../configure/RULES_BUILD:228: recipe for target
'epicsExceptionTest.o' failed
This happens on both base-3.14.12.5 and base-3.16.0.1.
That test does not appear in base-3.15.5
Note that
mrk> g++ --version
g++ (GCC) 6.3.1 20161221 (Red Hat 6.3.1-1)
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There
is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
The code that causes the error is:
static void epicsExceptionTestPrivate ()
try {
testFail("new char[%lu] returned %p",
(unsigned long) unsuccessfulNewSize, p);
catch ( const bad_alloc & ) {
testPass("new char[%lu] threw",
(unsigned long) unsuccessfulNewSize);
catch ( ... ) {
testFail("new: threw wrong type");
try {
char * p = new ( nothrow )
testOk(p == 0, "new (nothrow) returned %p", p);
catch( ... ) {
testFail("new (nothrow): threw");
In particular the statements:
and
It appears that the compiler now detects the problem instead of the
problem being detected at run time.
I commented out the code (thus test does not detect anything) and base
builds without error.
- fedora 25: epicsExceptionTest.cpp does not compile Marty Kraimer
RE: procServ 2.7.0-rc1 released Mark Rivers
<2017>
Concerns about link-support-2 branch Andrew Johnson
<2017>
