2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fix for building 3.15.4 on windows-x64-static
To: <[email protected]>
Date: Thu, 8 Sep 2016 10:47:58 -0500
On 09/08/2016 10:33 AM, Andrew Johnson wrote:
> On the other hand doing this kind of thing using the pre-processor and a
> #pragma optimize() setting is fast and localized, so I would much prefer
> that we stick with that solution if it can do what we need. You can tell
> whether you're building a dynamic binary there by the presence of the
> EPICS_BUILD_DLL macro.
By which I meant doing this inside the C/C++ source file that needs the
optimization turned off. We can even put compiler-specific header files
in src/libCom/osi/compiler/msvc if that kind of thing might help reduce
the amount of boiler-plate that needs to be added.
- Andrew
Fix for building 3.15.4 on windows-x64-static Mark Rivers
RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Re: Fix for building 3.15.4 on windows-x64-static Ralph Lange
Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
Prev: Re: Fix for building 3.15.4 on windows-x64-static Andrew Johnson
Next: RE: Fix for building 3.15.4 on windows-x64-static Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 08 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
