2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13
To: [email protected]
Date: Mon, 15 Feb 2016 20:49:16 -0500
On 02/15/2016 08:19 PM, Michael Davidsaver wrote:
> That "-1" stands out.  So far the only candidate I see is in
> dbCaPutLinkCallback() if the target link isn't connected or writable.
> Which would mean that the main thread is racing the dbCa thread to
> CA_CONNECT this link.
Ok, this is it.  So the obvious fix is to use/abuse caLink::monitor to
wait for the link to connect.
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
Build failed in Jenkins: epics-base-3.16-linux32-test #13 APS Jenkins
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
Prev: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
Next: Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Feb 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
