Subject: |
Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 |
Andrew Johnson <[email protected]> |
To: |
Date: |
Fri, 12 Feb 2016 11:33:58 -0600 |
Hi Michael,
On 02/12/2016 11:06 AM, APS Jenkins wrote:
> src/std/rec/test/O.linux-x86/arrayOpTest.tap ............. ok
> src/std/rec/test/O.linux-x86/asTest.tap .................. ok
> Bailout called. Further testing stopped: testMonitorWait() exceeds timeout
> FAILED--Further testing stopped: testMonitorWait() exceeds timeout
My fix was just to re-run the tests; given that this failure has
happened before on a different architecture, I think the 10 second
timeout delay in testMonitorWait() is just too short for a busy build
slave. Since the effect of failure is to kill all further testing I have
bumped it all the way up to 60 seconds.
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- Re: Build failed in Jenkins: epics-base-3.16-linux32-test #13 Michael Davidsaver
- Build failed in Jenkins: epics-base-3.16-linux32-test #13 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-linux32-test #14 APS Jenkins
Bug in dbGet() with server-side plugins Andrew Johnson
<2016>
<2016>
