On 10/07/2015 10:53 PM, Torsten Bögershausen wrote:
> Is this what you are asking for ?
> SEVR: NO_ALARM STAT: NO_ALARM TDIR: 0 TPRO: 0
Yes. So there is no active alarm.
> Beside that, caget mebtions "undefined" in both bases:
> IOC:m1.RBV <undefined> 0
Which means that the record's timestamp is 0, which suggests it has
never been processed.
Can you try doing something to make it process, then see if this changes
anything?
> Did I mention that I use the motor record ?
You didn't. Not what I would have picked for a simple test case, but it
probably makes no difference here :)
> Does this smell like a timig problem ?
I'm unsure. I suspect there is some variable which hasn't been
identified. I tried replicating with an aiRecord in a similar state (no
alarm and TIME==0), but can't get the alarm boarder in cs-studio nsls2
3.2.16a.
> record(ai, "foo") {
> field(SEVR, "0")
> field(STAT, "0")
> field(UDF, "0")
> field(VAL, "0")
> I remember that even in the codac version of everything (base, motor
> 6.81, CSS) sometimes the fields
> stayed pink all the time. But only sometimes.
> I will do some wiresharking on Friday.
> Thanks for the help.
> On 07/10/15 14:52, Michael Davidsaver wrote:
>> On 10/07/2015 08:45 AM, Torsten Bögershausen wrote:
>>> camonitor is fine, the PV IOC:m1.RBV) goes from <undefied> to 0.
>> What is the alarm severity of the record "IOC:m1"?
- CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Torsten Bögershausen
- Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Michael Davidsaver
- Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Torsten Bögershausen
Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Johnson, Andrew N.
<2015>
<2015>
