2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?)
To: Torsten Bögershausen <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Wed, 07 Oct 2015 08:01:02 -0400
On 10/07/2015 01:05 AM, Torsten Bögershausen wrote:
> Hej,
> I am chasing a problem that all PV's are shown as "Disconnected" in CSS.
> The pink overlay field.
> The values as such are updated, so they are not fully disconnected.
I'm confused.  The behavior you describe seems like an INVALID alarm
severity.  The fact that the values are updating means that the CA
connection is in fact being established.
Can you check one effected PV with command line 'camonitor' for both
Base versions?  Are there any differences in the outputs?
Also, while it might not be relevant in this case, when reporting a
potential CA connectivity problem please include some details about
relevant settings (EPICS_* environment variables, and cs-studio CA
perfs.), and the network topology (IOC and cs-studio on the same host,
or different).
> If no: I can trace with Wireshark
> (But don't have the CA plugin) , add debug code, run gdb.
https://github.com/mdavidsaver/cashark
shameless self promotion
Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Torsten Bögershausen
Prev: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Ralph Lange
Next: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Torsten Bögershausen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
