2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?)
To: EPICS Core-Talk <[email protected]>
Date: Wed, 7 Oct 2015 07:05:51 +0200
Hej,
I am chasing a problem that all PV's are shown as "Disconnected" in CSS.
The pink overlay field.
The values as such are updated, so they are not fully disconnected.
Tested under different CSS versions:
CSS 4.1.2 "Vanilla" , CSS 3.xxx from Codac.
Tested under different Linux: Centos 7, Ubuntu 2014 something
The common thing seems to be EPICS base; R3.14.12.5 is OK,
R13.15.2 is not.
A fresh compile with this version:
commit c74eb274740b487e6da87c95050d7b2d452ed583
Merge: 88864e9 5aa1459
Author: Andrew Johnson <[email protected]>
Date:   Fri Sep 18 11:51:51 2015 -0500
    Merged changes from 3.14 branch, to revno 12604
Seems to have the same problem.
Is this a known issue ?
(If yes: My apologies for SPAM)
If no: I can trace with Wireshark
(But don't have the CA plugin) , add debug code, run gdb.
Any ideas where to start are welcome.
Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Ralph Lange
Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Michael Davidsaver
Prev: RE: ASYN Device Support Issue Mark Rivers
Next: Re: ASYN Device Support Issue Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ASYN Device Support Issue Ralph Lange
Next: Re: CSS shows "Disconnected" for all PV's with Base 3.15.2 (?) Ralph Lange
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
