Hej Torsten,
Thanks a lot for your input!
On 23/09/2015 06:51, Torsten
Bögershausen wrote:
some loose thinking:
- (agreed with Andrew:) I think live is easier when snippets
should have an unique extension,
so that everybody (both the human and the Makefile) knows
what they are good for. ".iocs", ".isn" or why not ".ioc".
Point taken. I will add something to allow that.
I still like the "no dots" thing (idea taken from /etc/cron.*/
scripts on Linux) because it is an easy way to ignore all *.bk *.bak
*.orig *.old ... files without having to explicitly filter all of
these patterns.
- I like
the numbering
- Local overrides global, how to do that:
Does it make sense to re-order the command line, first things
first,
The first directory wins over the second:
Nah... well... matter of taste, actually.
I was thing along search path, include path, library path etc.
settings. All of these are searching directories in the order they
appear.
Maybe I should replace the multiple directories on the command line
with one argument, which is a search path.
There are a number of systems that do configuration over multiple
directories. What's needed in addition to plain combination is that
a local place must have ways to replace/remove things from a global
place, and a global place can provide defaults that when
copied/adapted in a local place will replace the global definition.
Do we really need the directory reading functionality ?
Typically the shell can do the wild card expansion,
"script -o st.cmd /my/ioc/st.cmd.d/*.ioc
/global/st.cmd.d /*.ioc"
or the make system (not 100% sure, please correct my if this
is wrong)
In terms of portability, I simply trust the functionality inside
perl to be more consistent than the very different shells on all our
different host platforms.
Another thing:
There is currently some "snippet development" going on here at
ESS,
together with the IOC factory.
Either I can dig out some more information (if your interested),
or you come and visit us to talk to the
developers directly.
That does sound interesting indeed.
I have seen two or three approaches to create st.cmd files so far,
but only one was snippet based.
Well... I am afraid I won't get travel approval for asking a
question about how to create a batch file. :-(
What is the time frame for the project, and the "pain factor" ?
First implementation next week (30 September), documentation and
release late October (Base 3.15.3).
Pain factor? Low.
For st.cmd, I have a local requirement for something more flexible
than creating a fixed blob and more comprehensive than series of
series of include files with fixed names. Any EPICS installation
larger than a handful of IOCs will think about creating st.cmd
files, based on global parts with local extensions or overwrites.
So I thought I would want Base to provide a mechanism that is
generic enough not to be a st.cmd solution only, while flexible and
comprehensive enough to be an easy way to solve 90% of the
prospective use cases.
On a related topic:
I really don't like TOP/iocBoot to be a source and an installation
directory at the same time. That causes trouble when creating
distribution packages for IOCs (have to sort out sources and
Makefiles from the stuff the IOC needs), "make uninstall" etc.
For 3.16, I would rather have TOP/iocBoot be a regular source
directory, and install the stuff for the IOC into TOP/ioc, which can
be treated as an installation dir, being packaged, thrown away at
Cheers,
~Ralph
- Re: RFC: Creating st.cmd from snippets Andrew Johnson
- RFC: Creating st.cmd from snippets Ralph Lange
- Re: RFC: Creating st.cmd from snippets Torsten Bögershausen
Re: RFC: Creating st.cmd from snippets Ralph Lange
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
