Hi Ralph,
On 09/22/2015 04:28 AM, Ralph Lange wrote:
> https://github.com/epics-base/epics-base/wiki/Simple-mechanism-to-create-files-from-ordered-snippets-(blocks)
My original thought was that the output file would only contain a list
of iocshLoad commands for all the snippet files that it found, not that
it would read in and spit out the contents of those files. This might
result in a much simpler Perl script, but it would then have to handle
the case where the IOC's directory tree looks different to the build
host. Your solution has different areas of complexity and simplicity but
overall is probably equivalent.
A few comments & questions on your document:
1. Why the design D03 for no dots in snippet filenames? I would suggest
a requirement that filenames all have the same specific extension such
as .cmd or .ish. GNUmake pattern rules are hard to get right without a
unique extension to hang them onto.
2. The pattern rule that runs the script will need a wildcard dependency
for each snippet directory, but then just removing a snippet file would
be insufficient to trigger a rebuild. Not sure this is going to be easy
to get right even when snippets have an extension.
3. R21 probably needs a bit more detail, e.g. where you set macro
values, and how expansion should handle environment variable macros in
the snippets. BTW there is an EPICS::macLib Perl module for when you get
to implementation, don't go writing your own.
4. D92 -- is the idea to add rules to base/configure/RULES.ioc or put
them in the iocBoot/ioc*/Makefile itself?
That's all for now, I may have more ideas later in the process.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
- Re: RFC: Creating st.cmd from snippets Torsten Bögershausen
- Re: RFC: Creating st.cmd from snippets Ralph Lange
- RFC: Creating st.cmd from snippets Ralph Lange
<2015>
<2015>
