See <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/1/>
[...truncated 209 lines...]
make[2]: Nothing to be done for `tapfiles'.
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/legacy/pcas/ex/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/legacy/pcas/ex'>
make -C ca/client/perl tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/client/perl'>
make -C O.solaris-sparc -f ../Makefile TOP=../../../../.. \
T_A=solaris-sparc tapfiles
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/client/perl/O.solaris-sparc'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/client/perl/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ca/client/perl'>
make -C ioc/db/test tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/db/test'>
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/db/test/O.solaris-sparc'>
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
Unable to lock the virtual address space using mlockall
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
Starting iocInit
Starting iocInit
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/db/test/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/db/test'>
make -C ioc/dbtemplate/test tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/dbtemplate/test'>
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
perl -CSD msi.t -tap > msi.tap
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/dbtemplate/test/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/ioc/dbtemplate/test'>
make -C ./std tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std'>
make -C O.solaris-sparc -f ../Makefile TOP=../../.. \
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/O.solaris-sparc'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std'>
make -C std/filters/test tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/filters/test'>
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
Starting iocInit
perl -CSD syncTest.t -tap > syncTest.tap
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/filters/test/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/filters/test'>
make -C std/rec/test tapfiles
make[1]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/rec/test'>
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/rec/test/O.solaris-sparc'>
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src/std/rec/test'>
make: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15-sol-test/ws/src'>
+ prove --failures --recurse --ext .tap --exec cat src
Unknown option: failures
Unknown option: ext
Unknown option: exec
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.solaris-sparc/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/arrShorthandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/arrShorthandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/callbackParallelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/callbackParallelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/chfPluginTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/chfPluginTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbCaStatsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbCaStatsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbChannelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbChannelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbLockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbLockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbPutLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbPutLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbShutdownTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbShutdownTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbStateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/dbStateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/recGblCheckDeadbandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/recGblCheckDeadbandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/scanIoTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/scanIoTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/testdbConvert.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/db/test/O.solaris-sparc/testdbConvert.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/dbtemplate/test/O.solaris-sparc/msi.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/ioc/dbtemplate/test/O.solaris-sparc/msi.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsAtomicTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsAtomicTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsExceptionTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsExceptionTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsInlineTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsInlineTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMMIOTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMMIOTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsSpinTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsSpinTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStackTraceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStackTraceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStdlibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStdlibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadHooksTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadHooksTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPoolTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPoolTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTypesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsTypesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/macDefExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/macDefExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/libCom/test/O.solaris-sparc/taskwdTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/arrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/arrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/dbndTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/dbndTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/syncTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/syncTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/tsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/filters/test/O.solaris-sparc/tsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/rec/test/O.solaris-sparc/analogMonitorTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/rec/test/O.solaris-sparc/analogMonitorTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/rec/test/O.solaris-sparc/arrayOpTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/std/rec/test/O.solaris-sparc/arrayOpTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Breaktable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Breaktable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/DBD.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/DBD.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Device.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Device.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Driver.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Driver.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Function.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Function.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Menu.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Menu.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Recfield.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Recfield.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Recordtype.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Recordtype.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Registrar.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Registrar.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Variable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/Variable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/macLib.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-sol-test/builds/1/tap-master-files/src/tools/test/O.solaris-sparc/macLib.tap].
TAP Reports Processing: FINISH
- Jenkins build is back to normal : epics-base-3.15-sol-test #2 APS Jenkins
Jenkins build is back to normal : epics-base-3.14-sol #3 APS Jenkins
<2015>
<2015>
