See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/27/changes>
Changes:
[Andrew Johnson] Merged changes from 3.15 branch to revno 12699
Started by upstream project "epics-base-3.16" build number 32
originally caused by:
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/> returned 0. Command output: "12659 [email protected]
" stderr: ""
[epics-base-3.16-win64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
bzr: ERROR: [Error 32] The process cannot access the file because it is being used by another process: u'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64'
ERROR: Failed to run bzr clean-tree
[epics-base-3.16-win64] $ bzr pull --overwrite lp:epics-base/3.16
Now on revision 12660.
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
M configure/RULES_BUILD
M src/ioc/db/callback.c
M src/ioc/db/dbCa.c
M src/ioc/db/dbCaPvt.h
M src/ioc/db/dbEvent.c
M src/ioc/db/dbScan.c
-D src/ioc/db/test/sRecord.db
M src/ioc/misc/iocInit.c
M src/libCom/misc/epicsUnitTest.c
M src/libCom/misc/epicsUnitTest.h
M src/libCom/test/epicsRunLibComTests.c
M src/std/dev/devAiSoftCallback.c
M src/tools/dbdToHtml.pl
All changes applied successfully.
[epics-base-3.16-win64] $ bzr revert
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/> returned 0. Command output: "12660 [email protected]
" stderr: ""
[epics-base-3.16-win64] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12660 revid:[email protected]
[epics-base-3.16-win64] $ cmd /c call C:\Users\jenkins\hudson2256121086038519635.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>make>
make -C ./configure install
make[1]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64'
make[1]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/configure'
make -C ./src install
make[1]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src'
make -C ./tools install
make[2]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools'
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/macLib.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Base.pm"
mkdir ../../../lib/perl/DBD
"Installing PERL_MODULES file ../../../lib/perl/DBD/Breaktable.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Device.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Driver.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Function.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Menu.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Output.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Parser.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recfield.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Recordtype.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Record.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Registrar.pm"
"Installing PERL_MODULES file ../../../lib/perl/DBD/Variable.pm"
"Expanding epics-base-windows-x64.pc@ to epics-base-windows-x64.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-windows-x64.pc"
mkdir ../../../lib/pkgconfig
"Expanding ../epics-base.pc@ to epics-base.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
"Installing created executable ../../../bin/windows-x64/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing created executable ../../../bin/windows-x64/cvsclean.pl"
"Installing created executable ../../../bin/windows-x64/dos2unix.pl"
"Installing created executable ../../../bin/windows-x64/expandVars.pl"
"Installing created executable ../../../bin/windows-x64/fullPathName.pl"
"Installing created executable ../../../bin/windows-x64/installEpics.pl"
"Installing created executable ../../../bin/windows-x64/makeIncludeDbd.pl"
"Installing created executable ../../../bin/windows-x64/makeMakefile.pl"
"Installing created executable ../../../bin/windows-x64/makeTestfile.pl"
"Installing created executable ../../../bin/windows-x64/mkmf.pl"
"Installing created executable ../../../bin/windows-x64/munch.pl"
"Installing created executable ../../../bin/windows-x64/replaceVAR.pl"
"Installing created executable ../../../bin/windows-x64/useManifestTool.pl"
"Installing created executable ../../../bin/windows-x64/genVersionHeader.pl"
"Installing created executable ../../../bin/windows-x64/dbdToMenuH.pl"
"Installing created executable ../../../bin/windows-x64/dbdToRecordtypeH.pl"
"Installing created executable ../../../bin/windows-x64/dbdExpand.pl"
"Installing created executable ../../../bin/windows-x64/dbExpand.pl"
"Installing created executable ../../../bin/windows-x64/dbdToHtml.pl"
"Installing created executable ../../../bin/windows-x64/podToHtml.pl"
"Installing created executable ../../../bin/windows-x64/podRemove.pl"
"Installing created executable ../../../bin/windows-x64/registerRecordDeviceDriver.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't open ../O.Common/EPICS/: No such file or directory.
"Installing generated html ../../../html/./EPICS/Getopts.html"
installEpics.pl: No such file '../O.Common/EPICS/Getopts.html' at ../../../src/tools/installEpics.pl line 53.
mkdir ../../../html/./EPICS
../../../configure/RULES_BUILD:473: recipe for target '../../../html/./EPICS/Getopts.html' failed
make[3]: *** [../../../html/./EPICS/Getopts.html] Error 2
make[3]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64'
../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src/tools'
../configure/RULES_DIRS:88: recipe for target 'tools.install' failed
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory 'C:/jenkins/win64-1/workspace/epics-base-3.16-win64/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is unstable: epics-base-3.16-win64 #28 APS Jenkins
- Build failed in Jenkins: epics-base-3.16-win64 #26 APS Jenkins
Jenkins build is back to normal : epics-base-3.15-win64-test #6 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32 #31 APS Jenkins
<2015>
<2015>
