2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.16-win32s #26
To: [email protected]
Date: Mon, 6 Jul 2015 11:57:10 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/26/>
Started by upstream project "epics-base-3.16-win32" build number 26
originally caused by:
 Started by upstream project "epics-base-3.16" build number 27
  Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>
[epics-base-3.16-win32] $ cmd /c call C:\Users\jenkins\hudson6395264518782653051.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>make> EPICS_HOST_ARCH=win32-x86-static
make -C ./configure install
make[1]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure'
perl -CSD ../src/tools/makeMakefile.pl O.win32-x86-static ../..
make -C O.win32-x86-static -f ../Makefile TOP=../.. \
    T_A=win32-x86-static install
make[2]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure/O.win32-x86-static'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure/O.win32-x86-static'
make[1]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/configure'
make -C ./src install
make[1]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src'
make -C ./tools install
make[2]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.win32-x86-static ../../..
make -C O.win32-x86-static -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools/O.win32-x86-static'
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base-win32-x86-static.pc"
"Installing PKGCONFIG file ../../../lib/pkgconfig/epics-base.pc"
mkdir ../../../bin/win32-x86-static
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Can't open ../O.Common/EPICS/: No such file or directory.
installEpics.pl: No such file '../O.Common/EPICS/Getopts.html' at ../../../src/tools/installEpics.pl line 53.
../../../configure/RULES_BUILD:465: recipe for target '../../../html/./EPICS/Getopts.html' failed
make[3]: *** [../../../html/./EPICS/Getopts.html] Error 2
make[3]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools/O.win32-x86-static'
../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86-static' failed
make[2]: *** [install.win32-x86-static] Error 2
make[2]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src/tools'
../configure/RULES_DIRS:88: recipe for target 'tools.install' failed
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory 'C:/jenkins/win32-1/workspace/epics-base-3.16-win32/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win32s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.win32-x86-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-win32s #27 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32s #25 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32 #26 APS Jenkins
Next: STATIC_ASSERT and -Wunused-local-typedefs Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Build failed in Jenkins: epics-base-3.16-win32s #25 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win32s #27 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
