2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.15-mac #40
To: [email protected]
Date: Thu, 18 Jun 2015 11:18:23 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-mac/40/changes>
Changes:
[Andrew Johnson] libCom: Fix routine name in error message
[...truncated 2185 lines...]
src/ioc/db/test/O.darwin-x86/dbLockTest.tap ............... ok
src/ioc/db/test/O.darwin-x86/dbPutLinkTest.tap ............ ok
src/ioc/db/test/O.darwin-x86/dbShutdownTest.tap ........... ok
src/ioc/db/test/O.darwin-x86/dbStateTest.tap .............. ok
src/ioc/db/test/O.darwin-x86/recGblCheckDeadbandTest.tap .. ok
src/ioc/db/test/O.darwin-x86/scanIoTest.tap ............... ok
src/ioc/db/test/O.darwin-x86/testdbConvert.tap ............ ok
src/ioc/dbtemplate/test/O.darwin-x86/msi.tap .............. ok
src/libCom/test/O.darwin-x86/blockingSockTest.tap ......... ok
src/libCom/test/O.darwin-x86/epicsAlgorithmTest.tap ....... ok
src/libCom/test/O.darwin-x86/epicsAtomicTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsCalcTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsEllTest.tap ............. ok
src/libCom/test/O.darwin-x86/epicsEnvTest.tap ............. ok
src/libCom/test/O.darwin-x86/epicsErrlogTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsEventTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsExceptionTest.tap ....... ok
src/libCom/test/O.darwin-x86/epicsExitTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsInlineTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsMathTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsMessageQueueTest.tap .... ok
src/libCom/test/O.darwin-x86/epicsMMIOTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsMutexTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsSockResolveTest.tap ..... ok
src/libCom/test/O.darwin-x86/epicsSpinTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsStackTraceTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsStdioTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsStdlibTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsStringTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsThreadHooksTest.tap ..... ok
src/libCom/test/O.darwin-x86/epicsThreadOnceTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsThreadPoolTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsThreadPriorityTest.tap .. ok
src/libCom/test/O.darwin-x86/epicsThreadPrivateTest.tap ... ok
src/libCom/test/O.darwin-x86/epicsThreadTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsTimerTest.tap ...........
Failed 8/41 subtests
src/libCom/test/O.darwin-x86/epicsTimeTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsTypesTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsUnitTestTest.tap ........ ok
src/libCom/test/O.darwin-x86/macDefExpandTest.tap ......... ok
src/libCom/test/O.darwin-x86/macLibTest.tap ............... ok
src/libCom/test/O.darwin-x86/ringBytesTest.tap ............ ok
src/libCom/test/O.darwin-x86/ringPointerTest.tap .......... ok
src/libCom/test/O.darwin-x86/taskwdTest.tap ............... ok
src/std/filters/test/O.darwin-x86/arrTest.tap ............. ok
src/std/filters/test/O.darwin-x86/dbndTest.tap ............ ok
src/std/filters/test/O.darwin-x86/syncTest.tap ............ ok
src/std/filters/test/O.darwin-x86/tsTest.tap .............. ok
src/std/rec/test/O.darwin-x86/analogMonitorTest.tap ....... ok
src/std/rec/test/O.darwin-x86/arrayOpTest.tap ............. ok
src/tools/test/O.darwin-x86/Breaktable.tap ................ ok
src/tools/test/O.darwin-x86/DBD.tap ....................... ok
src/tools/test/O.darwin-x86/Device.tap .................... ok
src/tools/test/O.darwin-x86/Driver.tap .................... ok
src/tools/test/O.darwin-x86/Function.tap .................. ok
src/tools/test/O.darwin-x86/macLib.tap .................... ok
src/tools/test/O.darwin-x86/Menu.tap ...................... ok
src/tools/test/O.darwin-x86/Recfield.tap .................. ok
src/tools/test/O.darwin-x86/Recordtype.tap ................ ok
src/tools/test/O.darwin-x86/Registrar.tap ................. ok
src/tools/test/O.darwin-x86/Variable.tap .................. ok
Test Summary Report
src/libCom/test/O.darwin-x86/epicsTimerTest.tap         (Wstat: 0 Tests: 41 Failed: 8)
  Failed tests:  14-21
Files=67, Tests=8894,  1 wallclock secs ( 0.62 usr  0.05 sys +  0.05 cusr  0.09 csys =  0.81 CPU)
Result: FAIL
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/arrShorthandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/arrShorthandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/callbackParallelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/callbackParallelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/chfPluginTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/chfPluginTest.tap].
org.tap4j.parser.ParserException: Error parsing TAP Stream: Missing TAP Plan.
	at org.tap4j.parser.Tap13Parser.parse(Tap13Parser.java:221)
	at org.tap4j.parser.Tap13Parser.parseFile(Tap13Parser.java:187)
	at org.tap4j.plugin.TapParser.parse(TapParser.java:140)
	at org.tap4j.plugin.TapPublisher.loadResults(TapPublisher.java:331)
	at org.tap4j.plugin.TapPublisher.perform(TapPublisher.java:253)
	at hudson.tasks.BuildStepMonitor$2.perform(BuildStepMonitor.java:32)
	at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:761)
	at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:721)
	at hudson.model.Build$BuildExecution.post2(Build.java:183)
	at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:670)
	at hudson.model.Run.execute(Run.java:1766)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:374)
Caused by: org.tap4j.parser.ParserException: Missing TAP Plan.
	at org.tap4j.parser.Tap13Parser.onFinish(Tap13Parser.java:502)
	at org.tap4j.parser.Tap13Parser.parse(Tap13Parser.java:219)
	... 13 more
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbCaStatsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbCaStatsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbChannelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbChannelTest.tap].
	... 13 more
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbLockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbLockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbPutLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbPutLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbShutdownTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbShutdownTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbStateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/dbStateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/recGblCheckDeadbandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/recGblCheckDeadbandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/scanIoTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/scanIoTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/testdbConvert.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/db/test/O.darwin-x86/testdbConvert.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/dbtemplate/test/O.darwin-x86/msi.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/ioc/dbtemplate/test/O.darwin-x86/msi.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsAtomicTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsAtomicTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsExceptionTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsExceptionTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsInlineTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsInlineTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMMIOTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMMIOTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsSpinTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsSpinTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStackTraceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStackTraceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStdlibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStdlibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadHooksTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadHooksTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPoolTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPoolTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTypesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsTypesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/macDefExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/macDefExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/libCom/test/O.darwin-x86/taskwdTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/arrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/arrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/dbndTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/dbndTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/syncTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/syncTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/tsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/filters/test/O.darwin-x86/tsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/rec/test/O.darwin-x86/analogMonitorTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/rec/test/O.darwin-x86/analogMonitorTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/rec/test/O.darwin-x86/arrayOpTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/std/rec/test/O.darwin-x86/arrayOpTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Breaktable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Breaktable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/DBD.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/DBD.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Device.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Device.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Driver.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Driver.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Function.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Function.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Menu.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Menu.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Recfield.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Recfield.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Recordtype.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Recordtype.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Registrar.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Registrar.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Variable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/Variable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/macLib.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.15-mac/builds/40/tap-master-files/src/tools/test/O.darwin-x86/macLib.tap].
TAP parse errors found in the build. Marking build as UNSTABLE
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.15-mac #41 APS Jenkins
Prev: Order of includes in build rules (base 3.14) Benjamin Franksen
Next: Jenkins build is still unstable: epics-base-3.15-win64s #164 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Order of includes in build rules (base 3.14) Andrew Johnson
Next: Jenkins build is back to normal : epics-base-3.15-mac #41 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
