See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/86/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> returned 3. Command output: "" stderr: "bzr: ERROR: No repository present: "file:///C:/jenkins/win64-1/workspace/epics-base-3.14-win64/"
[epics-base-3.14-win64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
ERROR: Failed to run bzr clean-tree
[epics-base-3.14-win64] $ bzr pull --overwrite lp:epics-base/3.14/
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
ERROR: Build step failed with exception
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> does not exist.
at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
at hudson.FilePath.glob(FilePath.java:1740)
at hudson.FilePath.access$1700(FilePath.java:191)
at hudson.FilePath$32.invoke(FilePath.java:1718)
at hudson.FilePath$32.invoke(FilePath.java:1715)
at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2688)
at hudson.remoting.UserRequest.perform(UserRequest.java:121)
at hudson.remoting.UserRequest.perform(UserRequest.java:49)
at hudson.remoting.Request$2.run(Request.java:325)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at ......remote call to win64-1(Native Method)
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1360)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:221)
at hudson.remoting.Channel.call(Channel.java:753)
at hudson.FilePath.act(FilePath.java:978)
at hudson.FilePath.act(FilePath.java:967)
at hudson.FilePath.list(FilePath.java:1715)
at hudson.FilePath.list(FilePath.java:1700)
at hudson.FilePath.list(FilePath.java:1686)
at org.tap4j.plugin.TapPublisher.locateReports(TapPublisher.java:438)
at org.tap4j.plugin.TapPublisher.perform(TapPublisher.java:224)
at hudson.tasks.BuildStepMonitor$2.perform(BuildStepMonitor.java:32)
at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:761)
at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:721)
at hudson.model.Build$BuildExecution.post2(Build.java:183)
at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:670)
at hudson.model.Run.execute(Run.java:1766)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:98)
at hudson.model.Executor.run(Executor.java:374)
Build step 'Publish TAP Results' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.14-win64 #87 APS Jenkins
- Build failed in Jenkins: epics-base-3.14-win64 #85 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win64s #81 APS Jenkins
Build failed in Jenkins: epics-base-3.14-win64s #82 APS Jenkins
<2015>
<2015>
