2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.14-win64 #85
To: [email protected]
Date: Wed, 10 Jun 2015 16:37:11 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/85/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/> returned 0. Command output: "12585 [email protected]
" stderr: ""
[epics-base-3.14-win64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.14-win64] $ bzr pull --overwrite lp:epics-base/3.14/
No revisions or tags to pull.
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
[epics-base-3.14-win64] $ bzr revert
" stderr: ""
[epics-base-3.14-win64] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12585 revid:[email protected]
[epics-base-3.14-win64] $ cmd /c call C:\Users\jenkins\hudson4004540188557104778.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>make>
make -C ./configure install
make[1]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/configure'
perl ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/configure/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/configure/O.windows-x64'
make[1]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/configure'
make -C ./src install
make[1]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src'
make -C ./tools install
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/tools'
perl ../../src/tools/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/tools/O.windows-x64'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
Rename failed: Permission denied
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
../../../configure/RULES_FILE_TYPE:62: recipe for target '../../../lib/perl/EPICS/Copy.pm' failed
make[3]: *** [../../../lib/perl/EPICS/Copy.pm] Error 13
make[3]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/tools/O.windows-x64'
../../configure/RULES_ARCHS:64: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/tools'
../configure/RULES_DIRS:87: recipe for target 'tools.install' failed
make[1]: *** [tools.install] Error 2
make[1]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src'
configure/RULES_DIRS:87: recipe for target 'src.install' failed
make: *** [src.install] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>make> tapfiles
make -C ./configure tapfiles
    T_A=windows-x64 tapfiles
make[2]: Nothing to be done for 'tapfiles'.
make -C ./src tapfiles
make -C ./tools tapfiles
make[3]: Nothing to be done for 'tapfiles'.
make -C ./makeBaseApp tapfiles
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/makeBaseApp'
perl ../../bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
Can't open perl script "../../bin/windows-x64/makeMakefile.pl": No such file or directory
../../configure/RULES_ARCHS:73: recipe for target 'O.windows-x64' failed
make[2]: *** [O.windows-x64] Error 2
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.14-win64/src/makeBaseApp'
../configure/RULES_DIRS:87: recipe for target 'makeBaseApp.tapfiles' failed
make[1]: *** [makeBaseApp.tapfiles] Error 2
configure/RULES_DIRS:87: recipe for target 'src.tapfiles' failed
make: *** [src.tapfiles] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-win64 #86 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32s #24 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64s #81 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Jenkins build is back to normal : epics-base-3.15-cyg64 #205 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64 #86 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
