See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/19/>
Started by upstream project "epics-base-3.16-win64" build number 19
originally caused by:
Started by upstream project "epics-base-3.16" build number 25
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>
[epics-base-3.16-win64] $ cmd /c call C:\Users\jenkins\hudson609417668898195068.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static host
make -C ./configure install.windows-x64-static
make[1]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/configure'
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64-static ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
T_A=windows-x64-static install
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64-static'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/configure/O.windows-x64-static'
make[1]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/configure'
make -C ./src install.windows-x64-static
make[1]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src'
make -C ./tools install.windows-x64-static
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64-static ../../..
make -C O.windows-x64-static -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64-static'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
installEpics.pl: Rename failed: Permission denied
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
../../../configure/RULES_FILE_TYPE:62: recipe for target '../../../lib/perl/EPICS/Copy.pm' failed
make[3]: *** [../../../lib/perl/EPICS/Copy.pm] Error 13
make[3]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools/O.windows-x64-static'
../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64-static' failed
make[2]: *** [install.windows-x64-static] Error 2
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools'
../configure/RULES_DIRS:88: recipe for target 'tools.install.windows-x64-static' failed
make[1]: *** [tools.install.windows-x64-static] Error 2
make[1]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src'
configure/RULES_DIRS:88: recipe for target 'src.install.windows-x64-static' failed
make: *** [src.install.windows-x64-static] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static tapfiles
make -C ./configure tapfiles
T_A=windows-x64-static tapfiles
make[2]: Nothing to be done for 'tapfiles'.
make -C ./src tapfiles
make -C ./tools tapfiles
make[3]: Nothing to be done for 'tapfiles'.
make -C tools/test tapfiles
make[2]: Entering directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools/test'
perl -CSD C:/jenkins64-1/workspace/epics-base-3.16-win64/bin/windows-x64-static/makeMakefile.pl O.windows-x64-static ../../../..
Can't open perl script "C:/jenkins64-1/workspace/epics-base-3.16-win64/bin/windows-x64-static/makeMakefile.pl": No such file or directory
../../../configure/RULES_ARCHS:70: recipe for target 'O.windows-x64-static' failed
make[2]: *** [O.windows-x64-static] Error 2
make[2]: Leaving directory 'C:/jenkins64-1/workspace/epics-base-3.16-win64/src/tools/test'
../configure/RULES_DIRS:88: recipe for target 'tools/test.tapfiles' failed
make[1]: *** [tools/test.tapfiles] Error 2
configure/RULES_DIRS:88: recipe for target 'src.tapfiles' failed
make: *** [src.tapfiles] Error 2
<https://jenkins.aps.anl.gov/job/epics-base-3.16-win64s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.16-win64s #20 APS Jenkins
- Build failed in Jenkins: epics-base-3.16-win64s #18 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win64 #19 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32 #24 APS Jenkins
<2015>
<2015>
