2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.16-win64 #19
To: [email protected]
Date: Tue, 9 Jun 2015 15:47:12 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/19/>
Started by upstream project "epics-base-3.16" build number 25
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/> returned 0. Command output: "12651 [email protected]
" stderr: ""
[epics-base-3.16-win64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.16-win64] $ bzr pull --overwrite lp:epics-base/3.16
Connected (version 2.0, client Twisted)
Authentication (publickey) successful!
Secsh channel 1 opened.
 M  configure/os/CONFIG.Common.vxWorksCommon
 M  configure/os/CONFIG.linux-386.Common
 M  configure/os/CONFIG.linux-486.Common
 M  configure/os/CONFIG.linux-586.Common
 M  configure/os/CONFIG.linux-686.Common
 M  configure/os/CONFIG.linux-x86.Common
 M  configure/os/CONFIG.linux-x86_64.Common
 M  configure/os/CONFIG_SITE.Common.vxWorksCommon
 M  documentation/README.1st
 M  documentation/README.html
 M  src/libCom/osi/os/vxWorks/osdStdio.c
 M  src/libCom/osi/os/vxWorks/osdWireConfig.h
bzr: ERROR: Failed to rename C:/jenkins64-1/workspace/epics-base-3.16-win64/.bzr/checkout/limbo/new-12 to C:/jenkins64-1/workspace/epics-base-3.16-win64/configure/os/CONFIG.Common.vxWorksCommon: [Error 5] Access is denied
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
ERROR: Failed to clean the workspace
java.io.IOException: remote file operation failed: <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/> at hudson.remoting.Channel@4f48da85:win64-1: java.io.IOException: Remote call on win64-1 failed
	at hudson.FilePath.act(FilePath.java:985)
	at hudson.FilePath.act(FilePath.java:967)
	at hudson.FilePath.deleteRecursive(FilePath.java:1169)
	at hudson.plugins.bazaar.BazaarSCM.pull(BazaarSCM.java:396)
	at hudson.plugins.bazaar.BazaarSCM.update(BazaarSCM.java:282)
	at hudson.plugins.bazaar.BazaarSCM.checkout(BazaarSCM.java:260)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1270)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:609)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:531)
	at hudson.model.Run.execute(Run.java:1741)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:374)
Caused by: java.io.IOException: Remote call on win64-1 failed
	at hudson.remoting.Channel.call(Channel.java:757)
	at hudson.FilePath.act(FilePath.java:978)
	... 13 more
Caused by: java.lang.ClassNotFoundException: java.nio.file.AccessDeniedException
	at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
	at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:421)
	at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:383)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:274)
	at java.io.ObjectInputStream.resolveClass(ObjectInputStream.java:624)
	at hudson.remoting.MultiClassLoaderSerializer$Input.resolveClass(MultiClassLoaderSerializer.java:116)
	at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1611)
	at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1516)
	at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1770)
	at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1349)
	at java.io.ObjectInputStream.readObject(ObjectInputStream.java:369)
	at hudson.remoting.UserRequest.deserialize(UserRequest.java:185)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:218)
	at hudson.remoting.Channel.call(Channel.java:753)
	... 14 more
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-win64 #20 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win64 #18 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-win32s #23 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win64s #19 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Build failed in Jenkins: epics-base-3.16-win64 #18 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-win64 #20 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
