2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Weird behavior when linking libgdd
To: [email protected]
Date: Tue, 05 May 2015 09:30:43 -0400
On 05/05/2015 08:40 AM, Ralph Lange wrote:
> On 05/05/2015 13:26, Michael Davidsaver wrote:
>> On 05/05/2015 03:43 AM, Ralph Lange wrote:
>>> The RPM check assumes the standard scenario where the 'build' target
>>> builds and the 'install' target installs. So you can safely have the
>>> debug information in the libraries contain the build location path,
>>> because the install moves it to a different location - and that new
>>> location is what the check-buildroot checks against.
>> Is this check really being done before debug symbols are (or would be)
>> stripped?  As I think about this, I would expect that this situation
>> would be handled by checking after the creation of a *-debuginfo .rpm
>> (using the ELF .gnu_debuglink extension).
> The check is being done after stripping. But:
> Only the shared libraries are stripped.
> The test fails for the static library and the debuginfo parts. The
> shared library passes.
> (This sounds silly. I know. Don't ask me.)
I agree, this sounds like a naive design.
Not sure what the the current incarnation looks like, but this old
version of check-buildroot can be bypassed by setting an environment
variable (QA_SKIP_BUILD_ROOT).
http://rpm5.org/community/rpm-devel/att-0747/check-buildroot
Weird behavior when linking libgdd Ralph Lange
Re: Weird behavior when linking libgdd Andrew Johnson
Re: Weird behavior when linking libgdd Ralph Lange
Re: Weird behavior when linking libgdd Michael Davidsaver
Prev: Re: Weird behavior when linking libgdd Ralph Lange
Next: Re: Base R3.15.2-rc1 release Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
