2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Weird behavior when linking libgdd
To: EPICS Core-Talk <[email protected]>
Date: Tue, 05 May 2015 09:43:49 +0200
Hi Andrew,
Wow.
I had almost forgot that circularity with gdd, and the trouble we had some years ago trying to make the build reliable.
In my poking around I basically went down the same path, but I hadn't seen the strings command trying to be clever, so I was puzzled with how linking would add the path to the archive.
Great detective work!
On 04/05/2015 19:23, Andrew Johnson wrote:
It's just that you changed your INSTALL_LOCATION without doing
a 'make clean' (as did I) so most of your .o files were not recompiled
and all the include directories in them still listed relative paths to
the $(TOP)/include directory. The gdd .o files tend to get rebuilt more
often than other files because of the circular dependency on gddApps.h
which is why you saw this there.
The RPM check assumes the standard scenario where the 'build' target builds and the 'install' target installs. So you can safely have the debug information in the libraries contain the build location path, because the install moves it to a different location - and that new location is what the check-buildroot checks against.
I think you'll have to remove the -g options from your
configure/os/CONFIG_SITE.Common.linux-x86{,_64} files to remove the
embedded build path, and don't forget to 'make clean' as well.
Hm - I don't want to lose the debugging info.
Instead, I will plainly 'install' the gdd libraries into the staging area, copying from the build, overwriting the ones that 'make INSTALL_LOCATION=...' put there. Now that I know it's safe to do so, that looks like the most appropriate thing to do.
Thanks a *lot*,
~Ralph
Re: Weird behavior when linking libgdd Michael Davidsaver
Weird behavior when linking libgdd Ralph Lange
Re: Weird behavior when linking libgdd Andrew Johnson
Prev: Re: Weird behavior when linking libgdd Andrew Johnson
Next: Re: Weird behavior when linking libgdd Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
