2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Small arrays in rsrv
To: [email protected]
Date: Fri, 03 Apr 2015 10:50:45 -0400
On 04/03/2015 10:29 AM, Ralph Lange wrote:
> Looking for a minimally invasive fix...
> Would you think it is possible and a good idea to base the queuing type
> decision (by value or by reference) on the size instead of the DBF type,
> so that arrays <= 64 bit total length (or maybe a configurable value)
> are put in the queue by value?
> That would solve our issue, and not create too much exceptionalism, right?
This would be a change to code handling db_field_log* correct?  On the
one hand I think the semantics of using this structure with arrays is
already complicated.
On the other hand enabling DB_EVENT_LOG_STRINGS gives sizeof(union
native_value)==40, which is certainly enough for your case.
I support an alternative would be a memory pool for small arrays (<128
bytes?).
Re: Small arrays in rsrv Andrew Johnson
Small arrays in rsrv Ralph Lange
Prev: Small arrays in rsrv Ralph Lange
Next: mbbi/mbbo default setting Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Small arrays in rsrv Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
