2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: variable-length-pCAS task
Cc: EPICS core-talk <[email protected]>
Date: Tue, 31 Mar 2015 14:54:26 +0200
> On 30 Mar 2015, at 17:45, Andrew Johnson <[email protected]> wrote:
> Hi Matej,
> On 03/30/2015 03:53 AM, Matej Sekoranja wrote:
>> Andrew Johnson wrote:
>>> Before merging this I think we would need to have an equivalent
>>> implementation for the CAS server so the PV Gateway can be made to
>>> support the newer version of the CA protocol. That does pose one problem
>>> though – the CAS doesn't do variable length arrays yet, it still only
>>> supports protocol revision 12 and you can't add this support without
>>> doing that first/as well.
>> ESS confirmed that I can work on variable-length-pCAS-support task.
>> Should I branch 3.15 or 3.16?
> Great! I would like us to consider this for inclusion in a future 3.15
> release, so I suggest you start there. If Ralph objects to that idea
> (since he's in charge of 3.15 releases now) it should be trivial to
> merge it into the 3.16 branch instead.
Just a quick question: I’ve updated CAS code and I want to test it. My plan is to take makeBaseApp example caServer and change scan method to change array size (aka new_size = (size+1) % 10).
However, I cannot get monitors working (I get no updates… even the first one). Is it supported to work? The code surely looks so. Note that it worked one time (one try out of 20) :/
Cheers,
Matej
> Thanks,
> - Andrew
> Light thinks it travels faster than anything but it is wrong.
> No matter how fast light travels, it finds the darkness has
> always got there first, and is waiting for it.
>    -- Terry Pratchett, Reaper Man
Re: variable-length-pCAS task Andrew Johnson
Prev: Build failed in Jenkins: epics-base-3.15-cyg64 #185 APS Jenkins
Next: Re: variable-length-pCAS task Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: variable-length-pCAS task Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
