2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: variable-length-pCAS task
To: Matej Sekoranja <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Mon, 30 Mar 2015 10:45:43 -0500
Hi Matej,
On 03/30/2015 03:53 AM, Matej Sekoranja wrote:
> Andrew Johnson wrote:
>> Before merging this I think we would need to have an equivalent
>> implementation for the CAS server so the PV Gateway can be made to
>> support the newer version of the CA protocol. That does pose one problem
>> though – the CAS doesn't do variable length arrays yet, it still only
>> supports protocol revision 12 and you can't add this support without
>> doing that first/as well.
> ESS confirmed that I can work on variable-length-pCAS-support task.
> Should I branch 3.15 or 3.16?
Great! I would like us to consider this for inclusion in a future 3.15
release, so I suggest you start there. If Ralph objects to that idea
(since he's in charge of 3.15 releases now) it should be trivial to
merge it into the 3.16 branch instead.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: variable-length-pCAS task Matej Sekoranja
Prev: Heads-up: 3.15.2-pre1 planned for next week Ralph Lange
Next: Build failed in Jenkins: epics-base-3.15-win64s #146 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: variable-length-pCAS task Matej Sekoranja
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
