2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ao record convert overflow
To: [email protected]
Date: Mon, 23 Mar 2015 17:45:25 +0100
Hi Andrew,
I think the part "value >= 0" works.
The add/substract of 0.5 before or after checking is a question of taste. In my proposal, 0.5 would be needed only once and after the "if" only the cast is to do.
The part "value < 0":
The test "value > (0.5 - 0x80000000)" means "value > (0.5 - (-2147483648)" == "value > +2147483648.5" if 0x80000000 is interpreted as 32-Bit long constant. If long is 64 bit on this system, the test is "value > (-2147483647.5)", which is OK.
If you write "value > (0.5 - 0x80000000LU)" this should work always.
Why did you change the type of ROFF? Since value is double when ROFF is substracted it doesn't cause problems even if ROFF is <0, I think.
What do you think of defining constants like "epicsInt32_MAX" and "..MIN" in epicsTypes.h?
Bernd
Re: ao record convert overflow Schoeneburg, Bernd
Re: ao record convert overflow Andrew Johnson
Prev: Jenkins build is back to stable : epics-base-3.14-mac #41 APS Jenkins
Next: Re: ao record convert overflow Schoeneburg, Bernd
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ao record convert overflow Andrew Johnson
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
