2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: recGblInitConstantLink broken in 3.16
To: "Johnson, Andrew N." <[email protected]>
Date: Tue, 17 Mar 2015 12:56:37 -0400
On 03/17/2015 12:36 AM, Johnson, Andrew N. wrote:
> Hi Michael,
> You can avoid Jenkins flagging versions with tests that you know will fail by wrapping them in a testTodoBegin("reason"); testTodoEnd(); pair, see epicsMathTest.c for an example. The tests still get run, but the harness knows they're supposed to fail.
Ok, I'll do this next time.
recGblInitConstantLink broken in 3.16 Michael Davidsaver
Re: recGblInitConstantLink broken in 3.16 Michael Davidsaver
Re: recGblInitConstantLink broken in 3.16 Johnson, Andrew N.
Prev: Build failed in Jenkins: epics-base-3.16-cyg64 #10 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-cyg64 #11 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: recGblInitConstantLink broken in 3.16 Johnson, Andrew N.
Next: Jenkins build became unstable: epics-base-3.16 #9 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
