Hi all
I just noted that we now use the compiler for .c and .cpp dependency
generation by default if CONFIG.gnuCommon is included. This apparently hides
the fact that either mkmf.pl or the rules invoking it are broken: the created
.d files are all empty except for the "# DO NOT EDIT: This file created by
mkmf.pl".
I stumbled over this due to a Makefile bug in the sequencer (I used 'ifdef
BASE_3_14' instead of 'ifeq (BASE_3_14,YES)' which caused a work-around for
base-3.14 to be enabled for 3.15, too).
The easiest way to reproduce this is by building an existing application
against 3.15 with
make HDEPENDS_METHOD=MKMF
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: mkmf.pl broken in 3.15? Johnson, Andrew N.
Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
<2015>
Build failed in Jenkins: epics-base-3.15-win64 #148 APS Jenkins
<2015>
