2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Base 3.14.12.5-pre1 Available
To: Benjamin Franksen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Mar 2015 17:01:00 -0600
Hi Ben,
Thanks for these patches, comments below:
On 02/28/2015 12:14 PM, Benjamin Franksen wrote:
> 1) fixed-release_perl_module_dirs.patch
> RELEASE_PERL_MODULE_DIRS is generated wrongly: <TOP>_LIB is not the same
> as <TOP>/lib.
Applied.
> 2) fix_-improve-misleading-_installing-____-messages-in-rules_db.patch
> This just fixes some "Creating..." messages.
Applied.
> 3) fix_-re_defined-echo-in-configure_os_config_common_rtems.patch
> We found that the RTEMS build system (we use 4.9) has its own definition
> of ECHO, so we re-define ECHO after including them.
Applied, but used the newer value of ECHO which is more portable.
> 4) fix_-release_cfg_config-and-_rules-should-be-in-reverse-order.patch
> RULES and CONFIG files from the cfg subdir of other modules must be
> included in the opposite order in which they appear in the
> configure/RELEASE file. This is because the RELEASE file lists them in
> reverse dependency order. This is the correct order when creating search
> paths (because in that case earlier entries win over later ones), but
> not when including make file snippets (because in that case later
> entries win over earlier ones).
You reversed the include order for the <top>/cfg/CONFIG* and
<top>/cfg/RULES* files, but not for the <top>/configure/RULES_BUILD
files. Wouldn't that make sense too?
> 5) extend-the-cfg-mechanism-to-rules_top.patch
> Finally one patch which adds a feature and is not a bug fix: in addition
> to adding RULES in a support module, this allows users to add TOP_RULES.
> In case it is not evident why this is useful, please shout and I'll
> explain.
I'd be interested in seeing your use-case, but I do think this is
probably worthwhile too.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
Base 3.14.12.5-pre1 Available Andrew Johnson
Prev: Build failed in Jenkins: epics-base-3.15-win64 #148 APS Jenkins
Next: Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
