On Thursday 26 February 2015 10:44:28 Andrew Johnson wrote:
> I created the 3.14.12.5-pre1 release yesterday and uploaded a tarball
> to the website. There have been a number of changes to the
> cross-build configuration files in recent days, so I would especially
> appreciate feedback on tests of linux-arm and derived targets. This
> build also supports cross-compiling for 32-bit Windows MinGW from
> Linux if you have the cross-build tools installed..
> The 3.14.12.5-rc1 release is slated for March 9th, and the final
> release for March 23rd assuming no major show-stoppers appear.
Hi Andrew
we have accumulated a number of small patches to the EPICS build system
over the years. I thought this would be a good opportunity to offer them
for merging with the mainline. I checked that they all (still) apply
cleanly to 3.14.12.5-pre1 (and did some cleanup, too).
1) fixed-release_perl_module_dirs.patch
RELEASE_PERL_MODULE_DIRS is generated wrongly: <TOP>_LIB is not the same
as <TOP>/lib.
2) fix_-improve-misleading-_installing-____-messages-in-rules_db.patch
This just fixes some "Creating..." messages.
3) fix_-re_defined-echo-in-configure_os_config_common_rtems.patch
We found that the RTEMS build system (we use 4.9) has its own definition
of ECHO, so we re-define ECHO after including them.
4) fix_-release_cfg_config-and-_rules-should-be-in-reverse-order.patch
RULES and CONFIG files from the cfg subdir of other modules must be
included in the opposite order in which they appear in the
configure/RELEASE file. This is because the RELEASE file lists them in
reverse dependency order. This is the correct order when creating search
paths (because in that case earlier entries win over later ones), but
not when including make file snippets (because in that case later
entries win over earlier ones).
5) extend-the-cfg-mechanism-to-rules_top.patch
Finally one patch which adds a feature and is not a bug fix: in addition
to adding RULES in a support module, this allows users to add TOP_RULES.
In case it is not evident why this is useful, please shout and I'll
explain.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
patch 0abae40e4caf07ff750b8e47a332e4f2f3f1d211
Author: [email protected]
Date: Tue Mar 4 13:53:53 CET 2014
* fixed RELEASE_PERL_MODULE_DIRS
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE new-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE
--- old-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE 2015-02-28 15:25:04.977516085 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE 2015-02-28 15:25:04.977516085 +0100
@@ -16,7 +16,7 @@
RELEASE_INCLUDES += $$(addprefix -I,$$(wildcard $$(strip $$($(1)))/include))
RELEASE_DBD_DIRS += $$(wildcard $$(strip $$($(1)))/dbd)
RELEASE_DB_DIRS += $$(wildcard $$(strip $$($(1)))/db)
- RELEASE_PERL_MODULE_DIRS += $$(wildcard $$($(1)_LIB)/perl)
+ RELEASE_PERL_MODULE_DIRS += $$(wildcard $$(strip $$($(1)))/lib/perl)
endef
$(foreach top, $(RELEASE_TOPS), $(eval $(call RELEASE_FLAGS_template,$(top)) ))
patch 7d2c39fd878254ba9d4d0cee6a2c13c103da62f5
Author: Ben Franksen <[email protected]>
Date: Sat Feb 28 15:26:22 CET 2015
* Fix: RELEASE_CFG_CONFIG and _RULES should be in reverse order
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/CONFIG new-base-3.14.12.5-pre1-hzb/configure/CONFIG
--- old-base-3.14.12.5-pre1-hzb/configure/CONFIG 2015-02-28 15:32:48.257738076 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/CONFIG 2015-02-28 15:32:48.257738076 +0100
@@ -89,7 +89,8 @@
ifneq ($(CONFIG),$(TOP)/configure)
RELEASE_TOPS := $(shell $(CONVERTRELEASE) -T $(TOP) releaseTops)
-RELEASE_CFG_CONFIGS = $(foreach top, $(RELEASE_TOPS), $(wildcard $($(top))/cfg/CONFIG*))
+RELEASE_TOPS_REVERSE := $(shell $(PERL) -e 'print(join(" ",reverse @ARGV))' $(RELEASE_TOPS))
+RELEASE_CFG_CONFIGS = $(foreach top, $(RELEASE_TOPS_REVERSE), $(wildcard $($(top))/cfg/CONFIG*))
ifneq ($(RELEASE_CFG_CONFIGS),)
include $(RELEASE_CFG_CONFIGS)
endif
--- old-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE 2015-02-28 15:32:48.257738076 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/CONFIG_APP_INCLUDE 2015-02-28 15:32:48.257738076 +0100
@@ -2,6 +2,7 @@
export IOCAPPS
ifneq ($(RELEASE_TOPS),)
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/RULES_FILE_TYPE new-base-3.14.12.5-pre1-hzb/configure/RULES_FILE_TYPE
--- old-base-3.14.12.5-pre1-hzb/configure/RULES_FILE_TYPE 2015-02-28 15:32:48.257738076 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/RULES_FILE_TYPE 2015-02-28 15:32:48.257738076 +0100
@@ -20,7 +20,7 @@
# Include <top>/cfg/RULES* definitions from tops defined in RELEASE* files
-RELEASE_CFG_RULES = $(foreach top, $(RELEASE_TOPS), $(wildcard $($(top))/cfg/RULES*))
+RELEASE_CFG_RULES = $(foreach top, $(RELEASE_TOPS_REVERSE), $(wildcard $($(top))/cfg/RULES*))
ifneq ($(RELEASE_CFG_RULES),)
include $(RELEASE_CFG_RULES)
endif
patch 3afcf301577012f0264d0e46f82f1c68ce5dead4
Date: Thu Aug 25 14:52:31 CEST 2011
* Fix: re-defined ECHO in configure/os/CONFIG.Common.RTEMS
Looks as if the included RTEMS Makefiles also define ECHO, so we
need to overwrite it.
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/os/CONFIG.Common.RTEMS new-base-3.14.12.5-pre1-hzb/configure/os/CONFIG.Common.RTEMS
--- old-base-3.14.12.5-pre1-hzb/configure/os/CONFIG.Common.RTEMS 2015-02-28 15:26:00.670501651 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/os/CONFIG.Common.RTEMS 2015-02-28 15:26:00.670501651 +0100
@@ -73,6 +73,8 @@
$(USR_CPPFLAGS) $(CMD_CPPFLAGS) $(ARCH_DEP_CPPFLAGS) $(OP_SYS_CPPFLAGS)\
$(OP_SYS_INCLUDE_CPPFLAGS) $(CODE_CPPFLAGS)
+ECHO := $(if $(findstring s,$(MAKEFLAGS)),\#,@echo)
# Although RTEMS uses gcc, it wants to use gcc its own way
CROSS_CPPFLAGS =
patch 6b56a781f336706bab27db43262358d6310054f3
Date: Wed Aug 24 14:23:31 CEST 2011
* Fix: improve misleading "Installing ..." messages in RULES.Db
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/RULES.Db new-base-3.14.12.5-pre1-hzb/configure/RULES.Db
--- old-base-3.14.12.5-pre1-hzb/configure/RULES.Db 2015-02-28 15:22:36.134885315 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/RULES.Db 2015-02-28 15:22:36.134885315 +0100
@@ -199,7 +199,7 @@
endif
$(INSTALL_DB)/%.substitutions: %.substitutions
- $(ECHO) "Installing db file $@"
+ $(ECHO) "Installing substitution file $@"
@$(INSTALL) -d -m $(INSTALL_PERMISSIONS) $< $(@D)
.PRECIOUS: $(COMMON_DIR)/%.substitutions
@@ -213,7 +213,7 @@
@$(RM) [email protected]
$(INSTALL_DB)/%.template: %.template
+ $(ECHO) "Installing template file $@"
.PRECIOUS: $(COMMON_DIR)/%.template
@@ -351,7 +351,7 @@
else
$(INSTALL_DB)/%: %
+ $(ECHO) "Installing $@"
endif
patch 331f4d7604b0979eabbd6c1949286384100234a7
Date: Sat Feb 28 15:29:28 CET 2015
* extend the cfg mechanism to RULES_TOP
diff -rN -u old-base-3.14.12.5-pre1-hzb/configure/RULES_TOP new-base-3.14.12.5-pre1-hzb/configure/RULES_TOP
--- old-base-3.14.12.5-pre1-hzb/configure/RULES_TOP 2015-02-28 15:34:28.427520937 +0100
+++ new-base-3.14.12.5-pre1-hzb/configure/RULES_TOP 2015-02-28 15:34:28.431521009 +0100
@@ -82,3 +82,10 @@
.PHONY: cleandirs distclean cvsclean realuninstall archuninstall uninstallDirs
.PHONY: uninstall help
+# Include <top>/cfg/TOP_RULES* definitions from tops defined in RELEASE* files
+RELEASE_CFG_TOP_RULES = $(foreach top, $(RELEASE_TOPS_REVERSE), $(wildcard $($(top))/cfg/TOP_RULES*))
+ifneq ($(RELEASE_CFG_TOP_RULES),)
+ include $(RELEASE_CFG_TOP_RULES)
+endif
- Re: Base 3.14.12.5-pre1 Available Andrew Johnson
- Base 3.14.12.5-pre1 Available Andrew Johnson
Jenkins build is back to stable : epics-base-3.14-mac #27 APS Jenkins
Build failed in Jenkins: epics-base-3.15-mac #8 APS Jenkins
<2015>
<2015>
