2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.14-win64s #48
To: [email protected]
Date: Tue, 17 Feb 2015 16:22:00 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64s/48/>
Started by upstream project "epics-base-3.14-win64" build number 52
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-win64s/ws/>
[epics-base-3.14-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\hudson3073051421992227243.bat
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64s/ws/>make> EPICS_HOST_ARCH=windows-x64-static
make: *** No targets specified and no makefile found.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64s/ws/>make> tapfiles EPICS_HOST_ARCH=windows-x64-static
make: *** No rule to make target `tapfiles'.  Stop.
<https://jenkins.aps.anl.gov/job/epics-base-3.14-win64s/ws/>exit> 2
Build step 'Execute Windows batch command' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.windows-x64-static/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-win64s #49 APS Jenkins
Jenkins build is still unstable: epics-base-3.14-win64s #47 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-win64 #52 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64 #53 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Jenkins build is still unstable: epics-base-3.14-win64s #47 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-win64s #49 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
