2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dbl output and record name aliases
To: [email protected]
Date: Tue, 06 Jan 2015 10:48:02 -0600
On 1/6/15 3:03 AM, Ralph Lange wrote:
> One-line-per-record-straight-ascii or XMLish?
Hi, Ralph.
I vote *not* XML.  My opinion is that any command available via the IOC
shell should produce, if anything, output typical of Unix-like commands.
The output should be easy for a human to read and possible to feed into
other Unix-like programs for further processing.  XML is neither.
Lewis
dbl output and record name aliases Ralph Lange
Prev: Re: dbl output and record name aliases Kasemir, Kay
Next: Re: dbl output and record name aliases Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: dbl output and record name aliases Johnson, Andrew N.
Next: Conversion issues (analog device support with float type raw data) Ralph Lange
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
