2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Possible bug in ca_clear_channel
To: Benjamin Franksen <[email protected]>, EPICS Core Talk <[email protected]>, Jeff Hill <[email protected]>
Date: Mon, 29 Dec 2014 12:00:29 -0600
Only one commit could have caused this change, to the 3.14 branch:
revno: 12415
committer: Jeff Hill [email protected] <[email protected]>
branch nick: trunk
timestamp: Thu 2013-05-16 12:33:31 -0600
message:
  merged in fix for https://bugs.launchpad.net/epics-base/+bug/1179642
  also merged in removal of c++ support for old HPUX compiler
http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12415
Unfortunately this was a rather large patch which introduced a new guard
to prevent a race condition, although many of the changes in it were
unrelated to delete dead code.
Jeff, will you be able to take a look at Ben's problem? If so please
work on the 3.14 branch and commit any fixes there; I will then be able
to merge them onto the 3.15 and 3.16 branches automatically, and will
also generate and publish patch files through the Known Problems pages.
I filed this as a bug report on Launchpad:
    https://bugs.launchpad.net/epics-base/+bug/1406331
- Andrew
On 12/28/2014 04:00 PM, Benjamin Franksen wrote:
> Hi All
> I recently added a few more tests to the sequencer, mostly concerned with the
> pvAssign function. This led to mysterious hang-ups: one of the new tests
> sometimes hangs right in the middle of a call to pvAssign. Further
> investigation revealed that the bug is not in the sequencer, at least not in
> any apparent way. When pvAssign is called with a connected channel, it first
> disconnects it by calling ca_clear_channel. What I see when instrumenting the
> relevant parts of the code with printf statements is that ca_clear_channel
> gets called but never returns. This does not happen every time, of course,
> it's highly timing dependent. I can reproduce it only about every dozen times
> I run the test. It only happens if the channel is on another IOC (but in my
> tests the other IOC runs on the same machine, in the background). When it
> happens it is always the first call to ca_clear_channel in the program that
> hangs. I looked at the code in src/ca/access.cpp and there has been a change
> between 3.14.12.3 and 3.14.12.4 in ca_clear_channel and it looks as if this is
> a regression because I cannot reproduce the problem with 3.14.12.3, but I can
> with 3.14.12.4 (and 3.15, BTW).
> The latest version 2.2 snapshot on the sequencer home page (seq-2-2-
> snapshot-2014-12-28.tar.gz) contains the test in test/validate/reassign.st. To
> reproduce, it is easiest to start the IOC with the database in the background
> like this:
> ben@sarun[1]: .../seq/branch-2-2 > cd test/validate/O.linux-x86_64
> ben@sarun[1]: .../validate/O.linux-x86_64 > ./reassign -S -d ../reassign.db &
> [1] 29640
> ben@sarun[1]: .../validate/O.linux-x86_64 > Starting iocInit
> ## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
> ## EPICS Base built Dec 28 2014
> iocRun: All initialization complete
> Then start the real test program as often as it takes. This is how far it gets
> when it hangs:
> ben@sarun[1]: .../validate/O.linux-x86_64 > ./reassign -S -t
> Sequencer release 2.2.0.3, compiled Sun Dec 28 22:40:58 2014
> Spawning sequencer program "reassignTest", thread 0x1a77490: "reassignTest"
> reassignTest[0]: all channels connected & received 1st monitor
> 1..30
> # start
> ok  1 - seq_pvChannelCount(seqg_env) == 3
> ok  2 - seq_pvAssignCount(seqg_env) == 2
> ok  3 - seq_pvConnectCount(seqg_env) == 2
> Cheers
> Ben
> "Make it so they have to reboot after every typo." -- Scott Adams
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Possible bug in ca_clear_channel Benjamin Franksen
Prev: Possible bug in ca_clear_channel Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 29 Dec 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
