2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Shutdown issues
To: <[email protected]>
Date: Thu, 20 Nov 2014 10:57:50 +0100
On Wednesday 19 November 2014 10:59:10 Ralph Lange wrote:
> Since Michael had to take back some of the epicsExit() changes, I was
> thinking about how to do a smooth transition to a smarter IOC
> shutdown/restart.
> This is coming back to a suggestion that Andrew had a few months back:
> Do we need a staged shutdown process with hooks for each stage -
> similar to the initHooks mechanism?
> At that point there would also be a clearer definition of which stages
> are shut down for a "hot standby" or a "warm complete restart" of the
> IOC.
> Maybe the module could also declare its name and functionalities, e.g.
> as an or'ed mask of features like "supports_standby",
> "supports_restart", "supports_link_change", etc so that the IOC core
> can decide if and how to do restart/shutdown and can provide better
> diagnostics.
> So that instead of simply setting
>      epicsAtExit(func, arg);
> a module would set things along the line of
>      id = epicsExitRegister("myModule",
> supports_standby|supports_restart); epicsAddExitHook(id,
> EXIT_BEFORE_CORE, func1, arg1);
>      epicsAddExitHook(id, EXIT_BEFORE_SERVER, func2, arg2);
>      epicsAddExitHook(id, EXIT_BEFORE_DBSCAN, func3, arg3);
>      epicsAddExitHook(id, EXIT_BEFORE_ERRLOG, func4, arg4);
> Compatibility - epicsAtExit could do
>          bla = epicsExitRegister("$$filename$$", 0);
>          epicsAddExitHook(bla, EXIT_BEFORE_CORE, func, arg);
> What do you think?
Hi Ralph
Yes, definitely. Make the dependencies and the relative order explicit.
Even though it does add more code, such a change makes the whole
shutdown thing more predictable and easier to reason about.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Shutdown issues Ralph Lange
Prev: Shutdown issues Ralph Lange
Next: Re: FW: Incorrect Timestamp in aSubRecord Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 21 Nov 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
