2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.15.0.2: Shutdown issues
To: <[email protected]>
Date: Wed, 19 Nov 2014 01:01:40 +0100
Hi Michael
All seems well now. Thanks!
Cheers
Ben
Am Dienstag, 18. November 2014, 15:12:37 schrieb Michael Davidsaver:
> On 11/18/2014 11:37 AM, Michael Davidsaver wrote:
> > From a quick look I would guess that at least dbBkptExit(),
> > dbLockExit(), and errlogExitHandler() can cause similar problems.  So
> > I'll look at making these conditional as well.
> Ok, so I think I've backed out enough of the DB cleanup to prevent
> crashing due to shutdown races.
> I think the remaining atexit hooks for softIoc shouldn't crash.  What is
> done is:
> > atExit exitDatabase((nil))
> For a real IOC (as opposed to a unittest) only doCloseLinks() runs to
> cleanup CA_LINK.  For records with extended device support it also
> disables "I/O Intr" scans and call del_record().
> > atExit ca_client_exit_handler((nil))
> Frees a thread local variable.
> > atExit dbCaExit((nil))
> Stops the CA link worker.
> > atExit cacExitHandler((nil))
> > atExit twdShutdown((nil))
> Stops the watchdog thread.
> > atExit errlogExitHandler((nil))
> Stops the errlog thread
> > atExit ClockTime_Shutdown((nil))
> Stops the ClockTimeSync() thread.
> None of these should free any global locks so that concurrent operations
> using these locks shouldn't operate on free'd memory.
"Make it so they have to reboot after every typo." -- Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
3.15.0.2: Shutdown issues Ralph Lange
Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Prev: Re: ringPointerTest Andrew Johnson
Next: Re: ringPointerTest Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Next: Re: 3.15.0.2: Shutdown issues Benjamin Franksen
ANJ, 18 Nov 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
