2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.15.0.2: Shutdown issues
To: [email protected]
Date: Mon, 17 Nov 2014 19:45:06 -0500
On 11/17/2014 06:24 PM, Benjamin Franksen wrote:
>> Since you are running the latest, can you arrange to set the global
>> variable atExitDebug=1 (defined in epicsExit.c)?  This should give some
>> clue about where in the exit sequence things are crashing.
> It ends now with:
> ...as before...
>     Results
>        Tests: 24
>       Passed:  24 = 100.00%
> Instance 0 of sequencer program "bittypesTest" terminated
> atExit 0x4055f0((nil))
> atExit dbProcessNotifyExit((nil))
Ok, so I ran your unittest :) and see the same.  I think this is an
actual bug which arises because dbProcessNotifyExit() doesn't block
until pending operations complete.
In this case the pending operation arising from seq_pvPut() as CA put
with callback operations now use dbNotify in 3.15.
Michael
3.15.0.2: Shutdown issues Ralph Lange
Re: 3.15.0.2: Shutdown issues Benjamin Franksen
Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Prev: Jenkins build is back to normal : epics-base-3.15-win64s #99 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-win32s #98 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: 3.15.0.2: Shutdown issues Benjamin Franksen
Next: Re: 3.15.0.2: Shutdown issues Benjamin Franksen
ANJ, 18 Nov 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
