See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/168/>
Started by upstream project "epics-base-3.15-win32" build number 101
originally caused by:
Started by upstream project "epics-base-3.15" build number 136
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on cyg64-1 (cyg64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/> returned 0. Command output: "12583 [email protected]
" stderr: ""
[epics-base-3.15-cyg64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.15-cyg64] $ bzr pull --overwrite lp:epics-base/3.15/
Unable to obtain lock file:///C:<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/> held by Jenkins Continuous Build server <jenkins@hudson> on HUDSON (process #5972), acquired 15 minutes, 13 seconds ago.
Will continue to try until 17:51:36, unless you press Ctrl-C.
See "bzr help break-lock" for more.
bzr: ERROR: Could not acquire lock "(local)": file:///C:<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/>
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.15-cyg64 #169 APS Jenkins
Jenkins build is back to stable : epics-base-3.15 #136 APS Jenkins
<2014>
<2014>
