Hi Folks,
I initially tried setting MDEL on the ai record that provides the pressure readback (which is the input to the ePID). I found that the ePID only controlled the output (the stepper motor) so that the pressure sat at the low or high limit of the MDEL, depending on which side it was approached from. So I needed some time factor to take the settling time into account (to reach the center of the deadband).
The motor record has deadbands for the monitors (MDEL and ADEL), but not on the input (except for the NTM logic to deal with backlash compensation).
On Aug 25, 2014, at 11:14 AM, "Dalesio, Leo" <[email protected]> wrote:
> Time can be captured in the integral term of the ePID. If that term continues to push the change up, it will exceed the position.
> Is that the argument for putting it in the ePID? We don't integrate the error if it is inside the deadband? Is this the only term that does not care inside a given deadband?
The output would be completely off (FBON=Off) if we have been within the deadband for N seconds. It would only turn on again (and reset the timer) if it drifts outside the deadband.
The idea is that the controlled variable may sit within the deadband for minutes or even hours without any further control needed (which in my case means switching a stepper motor amplifier on and off).
Cheers,
Matt
> This looks like a good discussion for either the code-a-thon or a side meeting at the EPICS meeting.
> From: Mark Rivers [[email protected]]
> Sent: Monday, August 25, 2014 11:03 AM
> To: Dalesio, Leo; 'Benjamin Franksen'; [email protected]; 'Core-Talk'
> Subject: RE: ePID deadband on output
> That's an interesting point.
> The motor record already has a deadband. Matt, did you try just using the deadband on the motor record?
> I don't think it has the concept of the time inside the deadband though.
> Mark
> -----Original Message-----
> From: Dalesio, Leo [mailto:[email protected]]
> Sent: Monday, August 25, 2014 9:51 AM
> To: Mark Rivers; 'Benjamin Franksen'; [email protected]; 'Core-Talk'
> Does the deadband belong on the ePID or the motor record?
> It seems like more of an output issue - not an algorithm issue.
> Bob
> From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
> Sent: Monday, August 25, 2014 10:39 AM
> To: 'Benjamin Franksen'; [email protected]; 'Core-Talk'
> Sorry for the delay in replying, this seems good to me as well.
> Mark
> From: [email protected] [mailto:[email protected]] On Behalf Of Benjamin Franksen
> Sent: Monday, August 25, 2014 5:14 AM
> To: [email protected]; 'Core-Talk'
> Subject: Re: ePID deadband on output
> [cross-posting to core-talk]
> On Thursday 14 August 2014 18:13:15 Pearson, Matthew R. wrote:
>> I'm using the ePID record to control a needle valve filling a cryostat
>> with helium. The needle valve is controlled by a stepper motor. The
>> ePID is giving good results, but I found the need for a deadband on
>> the PID output. This is to avoid continually driving the motor to and
>> fro by just a few steps. I implemented it via set of database
>> records, and included a timer to tell me how long the helium pressure
>> has been within a deadband, and then I disable the PID output (by
>> setting FBON).
>> However, I'm wondering if's a common enough use-case to be implemented
>> in the ePID record. It would mean adding some additional fields,
>> something like:
>> DBS - the deadband size
>> DBTS - settling time in the deadband (to avoid sitting on the edge of
>> the deadband) DBT - time in seconds since we entered the deadband
>> window
>> DBIN - binary flag to indicate we are in the deadband
>> If ABS(CVAL-VAL)<=DBS, and DBT>=DBTS seconds, then disable FBON.
>> If ABS(CVAL-VAL)>DBS then reset DBTS and enable FBON.
>> And to maintain current behavior, keep DBS=0 (the default).
>> The database version is working fine, but it's quite a few records and
>> I suspect it would be much simpler in the soft device support.
> Sounds like a pretty good idea to me.
> Cheers
> Ben
> "Make it so they have to reboot after every typo." ― Scott Adams
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
- Re: ePID deadband on output Bruce Hill
- Re: ePID deadband on output Benjamin Franksen
- RE: ePID deadband on output Mark Rivers
- RE: ePID deadband on output Dalesio, Leo
Re: Array data in db files? Benjamin Franksen
<2014>
<2014>
