2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Array data in db files?
To: [email protected]
Date: Mon, 25 Aug 2014 06:18:12 -0700
On 08/24/2014 12:42 PM, Benjamin Franksen wrote:
> The db/dbd syntax can be generalized to a very simple syntax that basically
> recognizes one kind of item:
>   item ::= keyword "(" arg "," ... ")" [ "{" item ... "}" ]
This would be ideal were it not for three things: embedded C code '%',
statements like 'addpath' which don't have '(', and break point tables
(just numbers).
What I have is the following where a 'value' is either a keyword, quoted
string, or number. "%.*$" is lexed as 'code'.
item ::= value '(' value ',' ... ')' [ '{' item ... '}' ]
        | value value
        | code
Break point table entries and "addpath" are parsed as "value value".
This definition parses all the existing dbd files I've tried so far from
base and synapps.
> The main point is that the syntax is now easily extensible by adding a new
> keyword and the corresponding function in the table. Unknown keywords
> (together with the item they introduce) are ignored (or optionally give
> warning), so that future extensions never break existing parsers.
Yup, this is the goal.
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Array data in db files? Benjamin Franksen
Array data in db files? Ralph Lange
Re: Array data in db files? Michael Davidsaver
Prev: Re: ePID deadband on output Benjamin Franksen
Next: RE: ePID deadband on output Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Array data in db files? Benjamin Franksen
Next: Re: Array data in db files? Benjamin Franksen
ANJ, 25 Aug 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
