2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Fri, 11 Jul 2014 17:27:16 -0000
On 07/11/2014 09:49 AM, mdavidsaver wrote:
>>> The testdbPrepare() routine could call eltc(0) ...
>> Ok.  ...
> I'm reconsidering this.  Do we really want to hide all messages?
Maybe not; several of our tests do trigger errlog warning messages from
the facilities they are testing, but I guess when that's expected the
test program should be using eltc to suppress them – there are three
programs in libCom/test and one in ioc/db/test that currently do that.
> Also, if this were done, shouldn't this be done in testPlan()?
That would couple the epicsUnitTest code directly to errlog which would
be a bad thing. Currently only some of the test programs will pull in
errlog, whereas the IOC definitely requires it to be present in the
executable.
You're right, that was probably not a good idea.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base Andrew Johnson
ANJ, 11 Jul 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
